Slow acceleration
Old Feb 22, 2011 | 06:02 PM
Ford12508's Avatar
Slow acceleration
I know that an F150 is not a race truck, but it seems like when I am at 40mph or so, and I floor it, it slowly creeps through second gear. At first I thought it was just going into third gear when I was flooring, but my RPMs are suggesting differently. I go into second gear and I can watch my tachometer slowly creep up. Is it normal that when flooring the pedal, the truck creeps up to speed so slowly? When I first got the truck it did not seem like it was this slow through second gear. Just wondering if anyone else can confirm it should be doing this.
Old Feb 22, 2011 | 06:59 PM
T.O.'s Avatar
Is it the 4.6??? Mine seems to do it too. It didn't feel like that when I first got it, but it could just be that you got used to the truck and you want more pep. Take the overdrive off and it'll wake up. BEWARE your GAS MILEAGE will suck if you do it.
Old Feb 22, 2011 | 07:03 PM
LateKnightRides's Avatar
It might needs a tune-up if it feels like it's boggy when you floor it. How many miles on your truck??
Old Feb 22, 2011 | 07:05 PM
azmidget91's Avatar
yep at about 40 you are over the cut off point for shifting down to first, so you are at the lowest rpm you can be in while in 2nd gear, which will have very low power, so in otherwords you are not in the power band yet and only way to fix it is to put a supercharger on or or put 4.10 or 4.56 gears in or make a 6 speed trans with closer gears in the truck
Old Feb 22, 2011 | 07:07 PM
mSaLL150's Avatar
You shouldn't floor it when in overdrive. That overdrive shift into 2nd is very rough on the transmission since it first must unlock the torque converter, then shift. Push the throttle halfway to get the torque converter to unlock (RPMs will rise and you'll feel it) and THEN hammer it so it can shift after.
Look into custom tuning. These trucks are dogs from the factory. Once I added custom tunes (with a couple other bolt ons) I gained nearly 45hp/50trq on the dyno and it would scream through 2nd gear.
Old Feb 22, 2011 | 07:12 PM
MGDfan's Avatar
==> https://www.f150online.com/forums/2357151-post13.html
BTW - disabling O/D with the button before nailing it will help reduce stress on the tranny... 4-2 downshifts are hard on it.
MGD
Old Feb 22, 2011 | 07:21 PM
Ford12508's Avatar
I was thinking it was normal like everyone is saying, just wanted to make sure. I realize the jump from 2.84 to 1.55 is a lot. And thanks for the tip on the 4-2 shift. I figure it wasn't the best, but I will try the 4-3-2 shift from now on.
Old Feb 23, 2011 | 04:09 AM
You sure you don't have plugged cats?
Old Feb 23, 2011 | 07:54 AM
Windsor's Avatar
These trucks have a delay to go to open loop. A tune can minimize the delay and increase performance in this circumstance.
Old Feb 23, 2011 | 08:51 AM
McStrokey's Avatar
In my 5.4 if im doing 40 in 4th gear and i floor it, itll dump all the way into 2nd and it scoots. by the time it shifts down and it passes through the gear it took 4 seconds.
