Confused!!!
Old Feb 7, 2011 | 07:04 PM
caseyjoeedwards's Avatar
Confused!!!
Ok, I have searched this site and know for a fact that you can fit 35's with a leveling kit. Hundreds of you have them right now. Yet I call 4wheel parts and they act like I'm an idiot. Here is my question. If I want to run a 20x10 kmc monster with 35x12.5's would -12 offset and a 5.03 backspace work with minimal trimming? Or what do I need to go with. Again, I wish I was bright enough on all this to just figure it out but I'm scared to buy without knowing for sure. anything would be great. Thanks!
Old Feb 7, 2011 | 07:19 PM
And by the way, the guy I talked to said he had a 6" lift and it rubbed.......could be somehow be talking about a 2wd or just doesn't know what he's talking about?? Guess I could also mention it is an 07 stx 4wd extended cab. Thanks again.
Old Feb 7, 2011 | 08:36 PM
quackrstackr's Avatar
I believe that guys running 35's with no problems are running a narrower wheel with a positive offset.
Old Feb 7, 2011 | 10:30 PM
kdevitt's Avatar
Casey I am at the same place. I read on here all the time about people running 35's. I will be interested to see the response that you get here. I have a 2007 FX4 with AS 2 1/2 level and rear AS AAL. I want to get 35 X 12.5 tires on XD Addicts with -12 offset and 4.5" BS. I am even willing to base my tire choice on wether it will fit / rub (within reason as I want it to be on the agressive side). I want to do a 6" lift at a later date and do not want to have to redo wheels and tires at that time.
KD
Old Feb 8, 2011 | 08:14 AM
ChuckTown4x4's Avatar
Im running a 33's on a -12 with 4.5 bs i dont rubat all so imsure you could run 35's with minor trimming my local rim shop told me the rims i have now will not work at all. . . . check out my album
Old Feb 8, 2011 | 08:51 AM
bossman15's Avatar
Ran the exact setup with quite a bit of trimming. Still rubbed pretty bad over bumps turning. I would Just wait til you save up more money and lift it or get a little smaller tire. Like a 305 55 20 or a metric equivalent to a 34x12...just my 2 cents.
Old Feb 8, 2011 | 09:01 AM
Big_Smokey's Avatar
KD
you will have to cut the crap out of your truck to fit a 35 with those wheels specs. I have a 20x9 wheel with -12 offset (4.5" of BS) and a 33/12.50/20 Terra Grappler. I rubbed on the front which was no big deal , but was really close on the fender well by the door, like probably a half inch or less...You will probably have to cut metal to fit those without rubbing and drive careful until you lift.
Old Feb 8, 2011 | 09:03 AM
Big_Smokey's Avatar
I dont think it is minor trimming when you cut sheet metal, but to each his own. i also had a 3" leveling kit and an AAL. I rubbed on the front and had to trim and on the OEM fenders. mine were 12.60 wide, keep in mind of your tire widths
Old Feb 9, 2011 | 08:31 AM
I'm guessing 33's will probably have to do then, especially since 50% of my miles are off road due to work. Sure would look good though, lol.
Old Feb 9, 2011 | 09:43 AM
colonelburke's Avatar
I'm running 20x10s with a -12 backspace and 33x12.5 Toyo MTs. I had to do a little trimming on the plastic front valance, but that is it. Close on the back fenderwell. I am leveled as well. I have a pic in my album of how far they stick out. Good luck.
Old Feb 9, 2011 | 12:05 PM
fivespeedsteed's Avatar
depends on the tire too. an mt with a smaller sidewall wont rub as bad as something with a crazy sidewall like a super swamper thornbird, or a mudgrapper.
Old Feb 10, 2011 | 08:00 PM
KD
That's exactly what I'm wanting to do. After I installed the front of the kit (because I messed up and didn't get the rear at the same time) It really looks like 35's would fit but that's looking at the stock tires.
Old Feb 10, 2011 | 08:43 PM
kobra_commader's Avatar
i got 35x12.50 on factory ford rims and i got no rubbing problems with a leveling kit
Old Feb 10, 2011 | 09:45 PM
jlyoung08's Avatar
im runnin 315's on stock and they barely touch the frame at full lock
Old Feb 11, 2011 | 01:14 PM
05BlackFX4's Avatar
like mentioned...you have to run a wheel with similar specs to stock to tuck 35's without rubbing and a leveling kit. Aftermarket wheels like the monsters will not allow you to run a 35" tire without trimming.
I have 33x12.5x20 Toyo MTs, 2" level, 4x4 with 20x9 XD Monsters. Check my gallery for a picture on the clearance of the tire vs the fenderwall and running board.
There is no way a 35" would fit without major trimming being done to the fenders. My 33's don't rub at all (forward, reverse, over bumps and while turning)
