F150 2wd w/ leveling kit...33" or 35" ?? any pics or comments will be helpful
Old Jan 23, 2011 | 12:33 AM
lowblueranger's Avatar
I've got a 2wd with a 2.5 autospring leveling kit up front, and a factory 4x4 block in the rear. Tires are 285/65/18 nitto terra grapplers. Rims are the typical xd monsters 18x9 with -18 offset. Barely rubs the front valence, but its easy to trim and you cant tell I touched it. I also have the 4.6 with 3.55 gears, and the truck seems just fine to me.
Old Feb 2, 2011 | 06:41 PM
camopaint0707's Avatar
does the 4x4 vs 4x2 make a difference when upgrading tire size?
Old Feb 2, 2011 | 07:46 PM
LTHL VNM's Avatar
2WD leveled with 33's
Old Feb 3, 2011 | 10:32 AM
wesshipman's Avatar
The 35" tires are going to look very cramped, but if you are going to go with a higher lift in the future I would go ahead and get the 35" tires. If you plan on sticking with the leveling kit, I would get 33" tires
Old Feb 3, 2011 | 12:11 PM
RandomHero34's Avatar
2.5 HBS level. Pro Comp 7005's with 285/65/18 Nitto Trail Grapps.
Old Apr 11, 2016 | 04:23 PM
Daniel Pallares's Avatar
<center>BEFORE</center>
<center>AFTER</center>
33's Nitto Grappler G2 A/T
3" Leveling Kit
Old Apr 13, 2016 | 09:01 AM
2008_XL's Avatar
3" Leveling Kit
That 3" level is going to destroy your suspension.
Old Apr 13, 2016 | 12:38 PM
Everything I have read says if you do offroading then don't go with the 3" lift, but I do not offroad in this truck. This is my daily driver on the streets of Southern Cali. The truck is 12 years old and probably already could use new shocks and suspension. But thanks
Old Apr 13, 2016 | 01:56 PM
2008_XL's Avatar
It's you're truck, but I was just giving you a heads up. Even if it doesn't leave the street, any bumps, potholes or speed bumps will max it out. Your upper ball joints are at the very end of their limit and have 0 down travel room.
Even if you replaced the entire front end, you'd still be going through parts quickly. 2.5" is really the max for these trucks.
How long have you had the 3" level?
But like I said, it's your truck and I was just trying to give a helpful opinion that the majority on this site would echo.
Old Apr 13, 2016 | 03:21 PM
Thanks for the input i do appreciate it.
I put in on about a week ago.
Old Apr 13, 2016 | 03:55 PM
2008_XL's Avatar
I wish you no trouble with the level. Your truck looks good. If you see issues, I'd really recommend a smaller spacer in the future if you have to replace parts.
Old May 26, 2021 | 10:07 AM
MrHarleyHall's Avatar
35s on a 2wd
Originally Posted by CaliKid
The time has finally come and im over riding on stock wheels and i need to make some decisions. I want to go with 20" XD Monsters and Nitto Mud Grapplers, but after seeing some pics I really want the 35's and dont mind trimming the inner fender. Should i be safe and go with 33's or go with the 35's and not look back if possible. Any pictures of 2wd f150's with 33's or 35's would help out a lot, and any other comments that will lead me in the right direction would be sweet such as rubbing issues and needed backspacing...
35s on a leveled 2wd
