Easy question about a squeaking engine pulley
Old Sep 9, 2010 | 03:05 AM
818F150's Avatar
I have a squeaking problem whilst acceleration with my 5.4 liter. Just recently I got it to do it on a cold start while the hood was up. And It looked/sounded like it was coming from the pulley all the way on the right, that isnt numbered. Can I disassemble this easily, and just take it off and clean it and what not? The shaft it rotates on looks rusted....
I have already replaced my motorcraft belt, with no change.
Pulley to the right of #5. It is un-numbered.
Old Sep 9, 2010 | 12:14 PM
jetech00001's Avatar
change it the bearing is probably shot
Old Sep 9, 2010 | 02:54 PM
818F150's Avatar
its not numbered idk what part # it is... Or even to take off the idler pulleys, do I just unbolt them?
Old Sep 9, 2010 | 03:50 PM
are you referring to #3 the belt tensioner
Old Sep 9, 2010 | 03:59 PM
davenay's Avatar
I just had #7 replaced because it sounded like it was about to explode. $42 part with $100 labor. If I had know for certain what it was before the dealer diagnosed it, I could have easily replaced it myself and saved the labor charge.
Old Sep 9, 2010 | 04:31 PM
818F150's Avatar
no, looking at the picture its the one to the right of #5. so to driver side.
Old Sep 9, 2010 | 07:57 PM
sam1947's Avatar
The pulley to the right of #5 (un-numbered) is your power steering pump. If that's whats noisy, your looking at a new pump.
Old Sep 9, 2010 | 07:58 PM
well right of the # 5 pulley is the water pump which is not listed in this diagram and to the left is the power steering pump and just to the upper right is the alternator hope this helps
Old Sep 9, 2010 | 08:05 PM
sam1947's Avatar
Refer to post #6 please..
Old Sep 9, 2010 | 11:59 PM
well if you look at the picture the right side of pulley 5 is the water pump left side is the power steering pump you have to look at the picture as the engine was setting in your truck.
Old Sep 10, 2010 | 03:27 AM
818F150's Avatar
Can I try disassembling Idler Pulleys and cleaning them and inspecting them first? If so, is it a simple unbolt and re-tighten? Or would I need to locktite or something?
Old Sep 10, 2010 | 07:04 AM
sam1947's Avatar
Just read what the OP said about the pic in post #6 "the pulley to the right in the pic on the driver's side " !! The OP is referring to the picture..not as if sitting in the truck !!
Old Sep 10, 2010 | 11:41 PM
jhunt47's Avatar
tried to read this post but a little confused the ones we see in the shop that go bad mostly is the number 5 idler part number 19a216 there was 4 of these replaced this week
