Sliding Rear Window Dead
Old Sep 5, 2010 | 10:37 PM
halobiont's Avatar
The small rear window won't open anymore. I took it to the dealer for another problem and they said the motor was shorted out. The repair was pretty expensive so I passed.
Any advice on replacing this motor myself or other troubleshooting tips.
Old Sep 5, 2010 | 11:15 PM
MGDfan's Avatar
This may help:
https://www.f150online.com/forums/ar...2004-08-a.html
https://www.f150online.com/forums/ar...ml#post4227148
For a motor - you can try a recycler...
Good luck.
MGD
Old Sep 6, 2010 | 09:04 AM
Gordon M.'s Avatar
If it's a Super Crew with a rear seat arm rest easy fix,Open the arm rest feel for a hard place in the seat back (behind where the arm rest folds up) have some one hold the switch them take a hammer I used the handle end hit the hard spot previously mentioned window should open lube cables with WD40 or other lubricant (top & bottom of window opening) Cycle window several times,Open window at least once a week to keep it working,Did this about 2 months a go to mine & it's still working fine
Old Sep 6, 2010 | 08:31 PM
6"_isnt_enough's Avatar
dude mine crapped out the other day when i tried to open it, then the next day it worked fine
Old Sep 7, 2010 | 10:11 AM
ChrisAU's Avatar
Mine quit for a few months, started working February of '08 and has been golden since.
Old Sep 7, 2010 | 10:43 AM
jdmeridith's Avatar
I know that they are starting to come out with some re-manned motors for these that typically run about $250. Pretty easy to do yourself. Most glass shops will quote you a whole new window that will prolly be in the $750 range for OEM. Do NOT go with an aftermarket! They will give you wiring issues and usually only last a year or so.
Old Sep 7, 2010 | 12:44 PM
halobiont's Avatar
Thanks. Ill give these a try and let you all know how it goes.
