Oil change question
Old Aug 26, 2010 | 07:25 AM
MGDfan's Avatar
Originally Posted by glc
Put in 6, run it for a couple minutes, let it sit for 10 minutes, then check it. If it's above the ADD line, don't put the 7th quart in.
I don't trust dipsticks, especially the one's on here
Dipstick calibration / variances versus oilpan dimensional stability and a Ford-published spec? I'll take the spec for $10, please.
FWIW - mine takes exactly 7 quarts, and it's just within the hash marks. Which I view as just a coincidence
MGD
Old Aug 26, 2010 | 04:45 PM
GTRider245's Avatar
Mine also takes all 7. Not to mention that's what they say to put in it...
Old Aug 26, 2010 | 05:32 PM
jntibs's Avatar
My 04 5.4 also takes all 7..... I would be curious as to what would make the stick show you're ok after 6. Are they punched out in Vietnam?
If you actually drain the oil, you will need 7, no matter what your stick says.
Unless you've got a 4.6, then you'd be looking at 6 qt.
Old Aug 26, 2010 | 08:57 PM
djjr50's Avatar
7 quarts of oil...(inscribes that to memory)
Has anyone used one of these quick-change plugs? I had the Fram one for my '79 Chrysler New Yorker when I was in college and I loved it! It keeps oil from splashing me and me trying to adjust my oil pan to catch the dieing flow.
And speaking of oil pans, anyone uses this over-sized oil & fluid pan? I like the size, but not the price! And the price doesnt seem to get much cheaper.
Old Aug 26, 2010 | 09:08 PM
jetech00001's Avatar
if you want a good quick drain check this link out i have used these valves for years and they are top notch. www.quickoildrainvalve.com
Old Aug 26, 2010 | 10:01 PM
djjr50's Avatar
I like the look of this valve...looks robust! Did you get the F106 one for the 5.4L V8?
Old Aug 26, 2010 | 10:53 PM
the f016n it has the nipple and the lever locks in place these are good quality .the ones you linked from ebay looked kinda cheap imo.
Old Aug 27, 2010 | 10:17 AM
bogeyrider63's Avatar
7 quarts put's me right in the middle of the hash mark's. 5.4L
Old Aug 28, 2010 | 10:14 AM
hmustang's Avatar
My 05 has taken all 7.
Old Aug 30, 2010 | 09:28 AM
osbornk's Avatar
Same with my 04.
