Any ideas
Old Jul 23, 2010 | 06:45 PM
Haus05's Avatar
Any ideas
Ok so the CEL came on, on the truck yesterday and it started the whole rough idle. It is an 05 with a 4.6, 94k. Now I know I need to do the whole plugs, fuel filter among a few other things, which will probably fix the rough idle, but what I am not sure of is that I went by AutoZone to have them scan it to see what codes it was throwing. He tried 4 times and gave him error every time, plugged it into his car it worked fine. Tried one more time on mine and gave him an error again. Any ideas?
Old Jul 23, 2010 | 06:51 PM
FordMan7's Avatar
do you have a chip? if so did you set it back to stock? cause master muffler had a hard time reading my truck and i figured out i left the chip in a different level...
Old Jul 23, 2010 | 06:57 PM
Haus05's Avatar
I don't think so. I have never put one in and they have scanned it before at this same AutoZone.
Old Jul 23, 2010 | 07:03 PM
jgger's Avatar
Check the fuse for the cigarette lighter, it has something to do with the test plug.
Old Jul 23, 2010 | 07:28 PM
Haus05's Avatar
Just check it. Still intact.
Old Jul 23, 2010 | 07:35 PM
jgger's Avatar
Does the lighter work?
Old Jul 23, 2010 | 07:39 PM
Haus05's Avatar
Yes
Old Jul 23, 2010 | 07:42 PM
jgger's Avatar
Then I don't know.
Sorry
Old Jul 24, 2010 | 11:00 AM
Haus05's Avatar
Well I unhooked the battery for a couple hours last night, CEL went off for a while, now back one... Anyone else have any ideas?
Old Jul 24, 2010 | 11:10 AM
shotgunz's Avatar
Could be a loose or bent pin or a loose connection on the OBDII port. Crawl under the dash and carefully inspect the pins and the connections on the back side of the port.
You could also try a different scanner at another store (NAPA, Pep Boys, etc.).
Last resort would be a trip to a mechanic or dealer.
Old Jul 28, 2010 | 10:07 PM
Haus05's Avatar
Ok finally finally figured out what it is. The rough idle part anyway, IAC motor. Any one know anywhere that sells it by itself. All the auto parts places I have checked can't get it, and the dealer only sells it with the throttle body for $275.
Got the Obd port issue figured out to, had a buddy borrow a scanner from a friend of his and it worked fine.
Old Jul 29, 2010 | 01:01 AM
The 05 doesn't have an IAC, it's an electronic throttle.
Old Jul 29, 2010 | 01:25 AM
ELVATO's Avatar
Try cleaning the throttle body opening. It might be gumming up.
Old Jul 29, 2010 | 08:07 AM
Haus05's Avatar
Ok well then I guess I am confused, this is the code is pulled.
P0506 Idle Air Control (IAC) System RPM Lower Than Expected
Old Jul 29, 2010 | 08:40 AM
ELVATO's Avatar
Yea, I think that's the code my dad's was getting. A search on here said to clean the throttle body with carb cleaner (I think I used electric parts cleaner), clear the code (you can do it by disconnecting the battery), and hooking everything back up. Problem solved.
