lights behind grill
Old Jul 8, 2010 | 02:46 PM
eddlestone213's Avatar
haha you're engine bay is about as dirty as mine! glad to see im not the only one too lazy to clean it
Old Jul 8, 2010 | 05:05 PM
88rxn/a's Avatar
thats awesome!
already existing bolts by by the looks of it?
Old Jul 8, 2010 | 06:47 PM
ozark f150's Avatar
yeah...the lower bolt on the headlights...now put the hbs kit on and order my exhaust, then I'll be done for a while
Old Jul 8, 2010 | 10:28 PM
tg150's Avatar
I did the same set up for my lights only I used a larger 1 1/2"x 1 1/2" angle iron. I also notched each end so they would fit in the into the headlight housing so I didnt have to cut any of the headlights plastic to bolt it on.. Then I used a grinder to polish it up nice and gave it 3-4 coats of rustoleum. Works great, lights dont shake and the bar is VERY sturdy.
Heres a pic:
Old Jul 8, 2010 | 10:39 PM
blaster_54738's Avatar
Originally Posted by GTRider245
That looks great. I am using that idea when I do my emergency light install in the grille.
you had to say that didn't you, i got some free off road lights from westin with my grille guard so i mounted them this way today, get a 40 in piece of angle iron, i think mine was 1 1/4x1 1/4. drill holes about an inch in from the end and bolt it on. now i need to find some emergency lights to put on it too...THANKS A LOT!!
Old Jul 8, 2010 | 11:01 PM
bigred1227's Avatar
thats awsome! Ive got a few questions and hopefully you can answer them!
What size bit did you use to cut the hole for the switch between the cig lighter and your backup switch?
and how did you run the wires from the lights to the battery and into the cab? Did you run it through the firewall or under the cab somehow? Ive been trying to figure this out for days. BTW i know 0 about how to run them so detailed explanation would be great! thanks!
Old Jul 8, 2010 | 11:21 PM
tg150's Avatar
Depends on what kinda lights you wanna wire.. "Search" feature will net you some good results..
Here's a thread, bottom of page 1 shows you how to wire Hella 500's.
https://www.f150online.com/forums/20...-mod-info.html
Old Jul 8, 2010 | 11:47 PM
TheCrazyredneck's Avatar
i was just about to ask about wireing. how long did it take to do it?
Old Jul 9, 2010 | 10:57 PM
GTRider245's Avatar
I just ordered 2 Whelen 500 series LIN6 LEDs in red. Hopefully they will be here in a few days. I'll be sure to post a new thread along with the rest of the lights in my truck.
