efans making ac not blow cold air at red lights
Old Apr 25, 2010 | 01:39 PM
bankrpt's Avatar
i have a set of efans with troyer controllers and spal fans, when driving down the road or interstate my ac blows REALLY cold but when i start to get in stop and go traffic or at a red light my ac is not cold at all. i dont have any over heating issues or any other type of problems any help would be great thanks.
Old Apr 25, 2010 | 01:46 PM
ELVATO's Avatar
Do they (both of them) turn on when you turn on the AC?
Old Apr 25, 2010 | 01:51 PM
bankrpt's Avatar
Yes I just went and checked they both come on when the AC kicks on
Old Apr 25, 2010 | 02:27 PM
ELVATO's Avatar
Well, not necessarily. I know some controllers have an AC input that turns on the second fan when the AC is turned on. Not sure if yours does or not.
It seems the way you have it connected is for 1 fan to turn on when the engine starts to heat up, then have the 2nd one turn on if things keep on heating up? Some people also use the second one as the "AC fan", so it's drawing air full blast when the AC compressor is engaged (or something like that).
Not sure if the Troyer controller has such an input.
Old Apr 25, 2010 | 02:45 PM
bankrpt's Avatar
No I pulled the fuse from one fan had the AC on the fan turned on so I pulled that fuse and put the other fuse back in and it turned on with the AC also so both turn on with the AC
Old Apr 25, 2010 | 05:40 PM
Tbird69's Avatar
But do they run full time for as long as the AC is on, or do they cycle on and off either on their own or in sync with the compressor?
Old Apr 25, 2010 | 05:59 PM
bankrpt's Avatar
When the compressor kicks on they kick on
Old Apr 25, 2010 | 06:51 PM
MGDfan's Avatar
Hello.
Wellsir - the only thing that comes to mind is the rpm of the compressor under freeway cruise versus stop&go / idling in traffic.
Airflow @ speed versus what the fans are pulling should be similar (as you said you do not see any temp rise / overheat conditions).
So - have yer A/C system checked - refrigerant levels, etc... perhaps?
Good luck.
MGD v5.0
Old Apr 25, 2010 | 07:07 PM
bankrpt's Avatar
Yeah I never thought about my AC levels maybe low ill get that checked thanks
Old Apr 25, 2010 | 10:55 PM
abercrfootball's Avatar
I have that same issue, I did some research and what I found was the blend door opening or closing when I come to a stop... I do not have the e fans installed though. So, you might be having the same blend door issue that I am having(I think)
If you figure the issue out please let me know because this is an annoying problem...
Old Apr 25, 2010 | 11:09 PM
bankrpt's Avatar
what the heck is a blend door lol
Old Apr 26, 2010 | 04:30 AM
code58's Avatar
Your coolant circulates all the time through the heater core so in order to give you "full" or "partial" heat OR A/C, the blend door opens or closes at infinite positions to "blend" the heat and cool to give you whatever you have selected in temp. The "blend door" sometimes break and fail to "blend" so you may well not have what you want or selected, because the "good old blend door" has fallen down and can't get up. Got the picture?
Old Apr 26, 2010 | 05:00 AM
bankrpt's Avatar
Oh OK well thanks
Old Apr 26, 2010 | 05:46 AM
brentswanton's Avatar
I had this same problem with mine while the truck was under warranty. Dealer replaced a blend door solenoid and havent had a problem since..
Old Apr 26, 2010 | 07:36 AM
Windsor's Avatar
There is a TSB on the actuator motor for the blend door. You may want to look into this. When mine started acting up at the end of summer last year, I had warm (heated) air coming out of the a/c vents. Since the motor's been replaced it's working like I would expect. I'm running Troyer's e-fans.
