Train Horn Help
Old Mar 23, 2010 | 09:26 PM
rednoved's Avatar
Exclamation Train Horn Help
Ok. So I have some Shocker Train Horns from HornBlasters and need some help with finding a good place to mount everything.
I have searched, but most of the pictures of what I need are now broken links, or the person who has the setup I would like, doesn't have any pictures, just words. Who doesn't have a camera on their phones these days.
The truck is a 2007 Supercrew with a 6.5 bed. It has the extra large tank. I have a spare tire, so using that location isn't an option. I don't have a tool box and need the bed space, so that isn't going to work either. I'm really open to suggestions after that. I would like a nice clean/hidden install. I could really use pictures, but descriptions of where some of yall have mounted them would be great too.
I have the Shocker XL Train Horns. Each horn has a 5" flare, and are 12.75", 14.75", 16.25", and 19.5" in length.
The compressor is a Viair 444C Air Compressor. It is a sealed compressor, so the outside elements shouldn't be an issue. It is 11.25" in lenth, 4.0" wide, 6.75" in height, and weighs 9.75lbs.
The tank is a 2 Gallon 6 Port Air Tank. The tank is 17" in length, 6" in diameter, 7" in height, and weighs 9.465lbs.
I know some people have mounted the horns in between the radiator and grille, which seems like a good place, but I'm not sure about how to mount them. I also noticed there was some space above the exhaust on the passenger side of the truck. Do you think heat would be an issue?
Any help is appreciated. Pictures are great.
Old Mar 23, 2010 | 09:30 PM
AntzFreshWhip's Avatar
i just have a set of horns with an air tank, no compressor. i mounted everything in the bed.
Old Mar 23, 2010 | 09:37 PM
rednoved's Avatar
Thanks for the reply. In the bed would be an easy install, I even have a cover for the bed, but I can't sacrifice any bed space.
Old Mar 23, 2010 | 09:38 PM
gcart's Avatar
^^^ i dont like that. easy to be stolen, bed use is taken, nope nope nope.
another option is along the frame rails.
Old Mar 23, 2010 | 09:46 PM
rednoved's Avatar
I know a few people said they mounted their tanks and/or compressors there. Do you have a horn setup?
Old Mar 23, 2010 | 09:51 PM
i have a cover and a tailgate lock. so it prevents theft alot. and i dont show anybody so they dont know...
Old Mar 23, 2010 | 09:56 PM
IORf150's Avatar
If you go to hornblasters website and click on installs, it actually shows you different trucks and how each person set theres up, I took my spare tire out and mounted mine right there. There really isnt too many places to put it
Old Mar 23, 2010 | 10:02 PM
coobies5's Avatar
i have everything but my horns mounted to my frame
when i have a free weekend, i plan on mounting my horns under the front of my truck behind the valence where a skid plate was at.
just mount everything along your frame and put the horns wherever there is room left
IORf150's Avatar
You cant even see mine unless you look under the truck heres a couple pics, my tank is mounted right behind my license plate and compressor is mounted about a foot away
[IMG][/IMG]
[IMG][/IMG]
Old Mar 23, 2010 | 10:09 PM
rednoved's Avatar
I looked through every install at hornblasters website before I purchase. Mainly the F150s though. One had everything in a toolbox. Another had it behind the grille, but the pictures were really crappy.
Old Mar 23, 2010 | 10:10 PM
gcart's Avatar
No sir just been around them my whole life. im gonna pick up a kit sooner or later. i run a spare also so mine will be along the frame. I will have a tank separate from the compressor so i can position everything how i want it.
rednoved's Avatar
The spare tire location is the best place, but I don't want to lose my spare, and I need the bed space for work.
Old Mar 23, 2010 | 10:18 PM
rednoved's Avatar
[IMG][/IMG]
[IMG][/IMG]
You have an awesome truck and setup btw.
Old Mar 23, 2010 | 10:20 PM
rednoved's Avatar
Do you have any pictures of the compressor or tank? I have seen your horns in the bed and the videos. Thanks.
Old Mar 23, 2010 | 10:30 PM
PaulBlackFX4's Avatar
I removed my spare and put it under the bed of my truck. It will soon go in my garage. I bought this thing called a cell phone. If I get a flat tire, I will call my wife and make her bring me the tire, or I will call AAA. I have the same exact setup you do. The tank is welded to the frame rail directly behind the plate, the compressor is mounted right next to it. The Horns are strapped down with several peices of plumber strap and screwed to the frame rails.
