Train Horn Help
Old Mar 23, 2010 | 10:40 PM
avfrog's Avatar
Mine are mounted there. I have a video pending!
Old Mar 23, 2010 | 10:57 PM
coobies5's Avatar
finally!
and i'll try and get some pics of my setup, my camera sucks on pics since the screen is broke
Old Mar 23, 2010 | 11:40 PM
abercrfootball's Avatar
This is where I mounted mine
Old Mar 24, 2010 | 12:17 AM
rednoved's Avatar
Originally Posted by coobies5
finally!
Old Mar 24, 2010 | 12:22 AM
rednoved's Avatar
Thanks for the pictures. I am considering doing the same thing. How are they mounted? Did you remove the bottom bolts from the horns, or did you use them? I really like your placement as I am limited on locations to put mine.
Do they sound good there, or are they muffled?
Where do you have your tank and compressor?
Sorry about all the questions, I just want to install my horns! I'm not a master fabricator, and I am limited on mounting locations, but your setup might work for me. Thanks again.
Old Mar 24, 2010 | 12:29 AM
rednoved's Avatar
I wish I had the means to make stuff like this.
That's pretty sick. I would like them all firing down anyways. But it looks legit.
Old Mar 24, 2010 | 12:31 AM
rednoved's Avatar
This was the one other install I saw with them behind the grille on an F150. Pictures don't have a high resolution, so it's hard to tell how its mounted.
Old Mar 24, 2010 | 12:47 PM
powerz69's Avatar
I like this as well, nice clean look.
Do tell where you put your tank?
Old Mar 24, 2010 | 07:41 PM
avfrog's Avatar
finally!
Video in my sig now...
Old Mar 24, 2010 | 10:02 PM
No, they sound great.... I removed the bolts on the bottom and I mounted the tank and compressor under the passenger side along the framerail
Old May 21, 2010 | 03:25 PM
HighOn22's's Avatar
So it looks like the only place to install them on a LIFTED f150 is where the spare tire goes? I have my horn there and my tank and comp in the bed. I would like to have my spare under the truck incase I need it just to get to the closest auto place if I despereratly need to. There seems to be no where else to mount the horns I have or tank. You'll be able to see the tank if it's along the chassis. Also the first compressor I had was under where the spare goes but burnt up I'm assuming due to being upside down.
