Hub assembly torque specs
Old Mar 9, 2010 | 05:03 PM
z2896's Avatar
Does anyone know what the torque specs are when replacing the axle hub assembly? I have a diagram from autozone and it shows 20 ft-lb for the 36 mm nut and 148 ft-lb for the four bolts that hold the assembly to the spindle. Are the numbers correct? Also, I'm replacing the upper control arms and these spec would be helpful too. Thanks.
Old Mar 9, 2010 | 05:08 PM
Paralyzer's Avatar
is this a 2004 heratige or new body style? 4x4 or 2wd?
Old Mar 9, 2010 | 05:59 PM
GATORB8's Avatar
FSM for the 06 4x4 shows (ftlbs):
Halfshaft nut - 20
Wheel hub bolts - 148
Upper ball joint nut - 85
Upper arm to frame nuts - 111
Shock absorber upper mount nuts - 35
Old Mar 9, 2010 | 09:01 PM
z2896's Avatar
It's a new body style 4x4. GATOR those sound the same as the autozone numbers so I'll go with them. Thanks.
