NEED HELP WITH WeatherTech MATS
Old Feb 15, 2010 | 09:42 PM
not again's Avatar
I just got my mats from WeatherTech but it does not seem to fit just right.I curls up under the driver door,ant it has a 2" play on the passenger side.
Can someone please post pictures of the front and back,any and all help is greatly appreciated!!
Old Feb 15, 2010 | 09:57 PM
Windsor's Avatar
There are numbers molded in the back of the mat. Write them down and call WeatherTech and see if they are right for your application. They sent me the wrong front mats for my truck, so they do make mistakes. I have those numbers in an e-mail, if you want to post them here.
Old Feb 15, 2010 | 10:49 PM
kurt14's Avatar
My mats did that too when I first got them... Sitting them out in the sun after washing them really makes them flexible... I'd contact Weathertech, it's possible storing them before you got them caused them to form wrong... It definitely sucks when you jump in your truck and you foot catches the edge... Other than that though they are the best floormats i've found and I absolutely love them...
Old Feb 15, 2010 | 10:52 PM
Carolinaboy32's Avatar
I love mine, But I noticed if they sit in the sun outside of the truck they will start to bow. So I put them in the garage when I'm cleaning the interior. Mine started to curl up when I bought em. I put a 10lb dumbbell on them overnight on the edge....problem solved
Old Feb 27, 2010 | 07:55 PM
not again's Avatar
I might be the only person on the planet to think that they should fit a lot better on the driver side.
I did not spend $258CDN to worry about it getting stuck under the door??
Old Feb 28, 2010 | 07:53 AM
Impact9's Avatar
Mine fit great. I'd guess you have to wrong set for your truck.
Old Feb 28, 2010 | 09:50 AM
not again's Avatar
Old Feb 28, 2010 | 10:30 AM
mblouir's Avatar
Yeah that's just a defective mat--looks like it got pinched somewhere and deformed. Send it back for replacement. Quality check was missed somewhere. Even if it will smooth out using methods mentioned (heat, weights, etc) you shouldn't have to do that since you paid so much for them.
Old Feb 28, 2010 | 10:50 AM
Average-Joe's Avatar
They should fit like a glove with very little play.
