Ford 'Gold' Remote Starter
Old Feb 27, 2010 | 09:39 PM
bheemsoth's Avatar
I picked up a used 2005 Lariat Crew this week, and it came with a remote starter installed, though none of the FOB's were included.
I crawled under the dash this afternoon, and it appears to be a Gold Series alarm installed by Ford and manufactured by Code Alarm.
These seem to be pretty common in our trucks, so I was wondering if anyone had any experience with these units, and knew how I might go about programming a new remote to work with it. I know the RKE remotes can be programmed somewhat easily, but wasn't sure about these.
Thanks in advance!
Brian
Old Feb 27, 2010 | 11:08 PM
paschalld's Avatar
Try going to the Audiovox web site. They are the makers of the Code Alarm and I have seen owners manuals, FOB's, etc..
If you have the serial number/model number off you unit, this may help also.
Hope this helps.
Old Feb 28, 2010 | 09:02 AM
bheemsoth's Avatar
Hope this helps.
Thanks for that tip. They had no documentation for the CA-610, but they had some for the CA-611, which I assume may be similar. Unfortunately they did not mention anything about how to program a new fob.
Old Feb 28, 2010 | 10:01 AM
bheemsoth's Avatar
After some more searching I was able to track down an installation manual on the following site: http://www.the12volt.com/installbay/file.asp?ID=735
Registration might be necessary, but the manual includes wiring and programming information for all compatible Ford vehicles.
I then was able to pick up a replacement FOB on ebay for $20. http://cgi.ebay.com/ebaymotors/ws/eB...m=380175969993
For future reference, the model number of the FOB is GOH FRDPC2002
Old Feb 28, 2010 | 12:33 PM
paschalld's Avatar
Good work on getting the FOB. Good price.
Forgot to mention last night on programming the FOB, if you go to the Technical Articles directory and do a search for either "FOB" or "PATS Thread" you can find a how-to on programming keys and FOB's. It's pretty straight forward and I've used it a couple of times.
