Evolution problem
Evolution problem
I have an 08 stx 4.6l with the Edge Evolution. When I would drive down my street from my house to the light at the end and make the turn, my truck would bog down and run like crap. I would pull over asap and look up the code through the Edge and it told me that it was an internal throttle control module problem or something like that. I don't remember the exact words. I always programmed it back to stock at that time and have no problems driving it in stock mode, other than the lack of fun. I am thinking that it happens the most when the weather is cold out and my truck isn't up to temperature yet because I just left my house. I also had this problem back when I had my K&N intake installed and just got the Edge. Any ideas what this code is telling me and is something wrong with my truck now? Also if I upgraded, would a Gryphon programmer not give me this problem?
Why dont you write these things down??? Difficult to help without exact codes. It's like going to the doc saying " I hurt"
Try Contact Edge Support - you paid for it
Perhaps you need a tune tevision update - from them. Did you check for one online?
All of that is in the manual....
Waiting for the code .....
I just remembered where I wrote it all down at. The code said P061F Internal Control Module Throttle Actuator Controller Performance. I'm new to the site and figured I would start asking here because I have searched about this code before and people have said that Edge doesn't help that much, all they tell you is to update. I have checked for updates 3 or 4 times and it tells me there are no updates.
Ok.
Failsafe Mode...
Does not do it stock correct - confirm this first by driving it for a while.
If not, then yer TB/ETC hardware is probably fine ( I suppose you could try to clean it anyway), and there may be a marginal tune incompatability with your strategy under certain conditions.
A custom tune may address this - but do not depend upon tuning to fix a legitimate mechanical/electrical issue.
Plug that code into this site's advanced search engine & start reading - that's yer homework fer today
Aww cap - here's just one of many ===>https://www.f150online.com/forums/ch...de-w-edge.html
Failsafe Mode...
I suggest you return to stock, remove the Evolution and connect it to your PC and be sure you have the latest software/firmware by doing an update through the Fusion software. Eliminate this as a possible problem before going any further.
Just my two cents...I don't need change.
Good luck.
I would strongly suggest you contact Edge. My experiences with them (only one or two times) have been 100% positive. Their customer support is top notch.
Good luck.
Good luck.
Eliminate the tuner variable first. I'd hate for you to R&R that TB if the root cause was actually something else ...
Lots to read ...
Going to leave this one in this forum as it may be more engine related than tuner. if it becomes more of an Edge issue, will move it to the Chips and tuner forum. Thanks
Another thing that has also happened was where the odometer is, 2 different times after startup it would say trans fault. I then shut off the truck and waited a minute or so, restarted and the message went away. I didn't have to change the programming level so I don't think that was my tuner but I have no idea. Anybody come across that before?
To me it is starting to sound more and more like a PCM communication issue. Try disconnecting the three connectors and blowing on them to clear out any potential debris. You do this by lifting the grey lever on each connector at the PCM (located on the passenger side firewall) and then pulling back, CAREFULLY, on the connector. Don't forget...DISCONNECT YOUR BATTERY FIRST!!!! Just wanted to be clear on that. Let's eliminate that possibility as well. I'm not saying it IS a PCM issue but go ahead and spend the 5 minutes doing this and get that out of the picture.
Just heard back from Edge about the P061F code. They said to go to the dealer because there is a TSB for the codes and that the dealer has a PCM update that would resolve that. What will that do to me as far as using my Edge after they update the PCM and what would the dealer charge me to do this? My truck is under warranty so would it be covered????
Make sure you are returned to stock before you go to the dealer. Not sure what the dealer will say, but have them check it out. Normally, they will reflash underwarranty, mine did. Your Edge will work afterward if that HEX is in it's list. If not, you will need to get Edge to update their list of HEX codes.
1. It will keep them unaware that you have a programmer. Some dealers don't endorse programmers.
2. It will prevent anyone with sticky fingers from slipping your Edge in their pocket.
