2006 ford f-150 4x4 xlt four wheel drive went out
Old Jan 2, 2010 | 08:30 PM
CEdmonds4x4's Avatar
I own a 2006 ford f150 4x4 xlt and just recently my four wheel drive light and four wheel hi and low will not engage. I took it pheasant hunting and when i got back it stopped working. I dont believe I went over 45 in the cold conditions, and have no idea why it wont engage. I rarely use the four wheel drive, I only use it in the winter when I am hunting and sometimes to pull people out of mud and ditches. If anyone has any input it would be great.
Old Jan 2, 2010 | 08:57 PM
kd4crs's Avatar
Sounds like the electronic shift motor on the rear of the transfer case has gone south. Give it a tap or two with a hammer and try the 4WD afterwards and see if it works. If it does you will be replacing that electronic shift motor soon.
Old Jan 3, 2010 | 10:38 AM
okstategrad2002's Avatar
I had the same problem one time with my 2006. It only happened once, when I actually needed it during mud season. Unfortunately I had to get pulled out by a Chevy. Once I got pulled out, I tried to engage it one more time, and wala, it worked! Havent had any other issues with the 4x4 since this happened last year.
Old Jan 3, 2010 | 10:55 AM
Cdn-Redneck's Avatar
My 05 shift motor quit on me and had it replaced under warranty.
Old Jan 3, 2010 | 03:04 PM
beige150's Avatar
I had a 2006 leased xlt that the 4x4 went out in at 36,000 miles. I turned it in without getting it repaired. I now have a 2007 stx that it just went out in at 44,700 miles. This was a sensor that went out. I think its a problem that Ford should address. My Ford's with manual lever and lock out hubs, never once had a problem. If offered on a 150 that is the route I would go.
Old Jan 3, 2010 | 05:00 PM
2stroked's Avatar
I'll second the motion - or in this case - lack of motion. Nine times out of ten this will be the problem with the symptoms you mentioned.
BTW, replacing the ESOF motor is a piece of cake too, so don't pay somebody big bucks to do it. It's located right on the back of the Transfer Case.
Old Jan 3, 2010 | 06:00 PM
avfrog's Avatar
Mine got stuck in 4 low once. I just kept playing with until it kicked out. This was before I knew the route of the problem. I have used it several times since with no problems.
Old Jan 3, 2010 | 06:58 PM
aPINCHbetter90's Avatar
had the same problem in my '06 it was the transfer case.
Old Jan 4, 2010 | 12:48 AM
Tornadom's Avatar
I've never had problems with 4wd engaging or disengaging on my '06, but then again, I have to reach down and shift it myself.
