TRUE leveling kit gain
Don't know if you guys worked this out yet, but here's my experience. I put an AS 1.5 leveling kit on my 04 screw. The part actually measures 1.25 and it lifted the truck 2.5. So be careful what you get. I ended up ordering the 1" urethane kit from daystar and will cut it to 3/4" to get the 1.5 since whatever the actual size of the shim is will double the lift it says it will provide.
I have the daystar 2.5 kit on my 06 f150 screw lariat. The front definitely sits higher than the rear, which made me order a 3 inch block for the rear, which i still have to install.
but from the right angle it looks level:
