How to: Disable Perimeter Lighting (Save your HIDs!!)
Old 10-19-2009, 10:49 PM
mblouir's Avatar
This question was just asked and I've seen it asked a few times before. It's hiding in the manual in the section on the keyless entry, of all places. Pretty hard to find.
With so many members changing over to HIDs I thought this was worth a post. Since they require a heat up/cool down period, it's a great idea to disable the perimeter lighting feature on our trucks.
What is perimeter lighting?
When you press the unlock button with your keyless entry fob, the headlights come on for ~25 seconds. It is used to illuminate the exterior of the vehicle and give better visibility to the user while approaching the vehicle.
Why disable it?
The perimeter lighting feature will, to be blunt, greatly reduce the life of your HIDs. The constant flickering on and off from the perimeter lighting causes unnecessary wear on the bulbs since they don't have time to properly warm up or cool down before their next use.
How to disable it.
Straight from a 2007 Ford F-150 Owner's Guide:
Originally Posted by F150 Manual, pg. 137
Enabling/Disabling the perimeter lighting feature
Your vehicle comes with the perimeter lighting feature enabled. All vehicle doors must be closed before beginning the procedure. You must complete Steps 1-5 withing 30 seconds, or the procedure will have to be repeated. If the procedure needs to be repeated, you must wait a minimum of 30 seconds to begin again.
1. Turn the ignition to the ON position, then press the unlock control three times.
2. Turn the ignition to the OFF/LOCK position, then press the unlock control three times.
3. Turn the ignition to the ON position; the horn will chirp to indicate the driver configuration mode has been activated.
4. Within five seconds, press the unlock control two times.
Note: One horn chirp should be heard, indicating the system has been disabled. Conversely, a horn chirp followed by a honk will indicate the system is enabled. Pressing the power door unlock control two times again will turn the feature ON if it was previously OFF, or OFF if it was previously ON. Every two consecutive presses of the unlock control after successfully entering the configuration mode will change the enable/disable condition of the feature.
5. Turn the ignition to the OFF/LOCK position to exit programming.
Note: After exiting the driver configuration mode, the horn will chirp once to indicate a feature has been activated/deactivated.
Hope this helps some of you guys out! Oh yeah, please readjust your HIDs after installing them. Now that you've readjusted them, aim them a bit further down.
Old 10-19-2009, 11:10 PM
08FX4's Avatar
Good post and this should answer A LOT of questions.
Old 10-20-2009, 12:17 AM
bambo2888's Avatar
is it reverse for enabling the feature?
Old 10-20-2009, 12:20 AM
mblouir's Avatar
Yeah the note for Step 4 is a little confusing. Basically do the exact same process to reverse it. If it is enabled the horn will chirp then honk, as opposed to just chirping for being disabled.
Old 10-20-2009, 12:22 AM
Tuff4rd's Avatar
Awesome post, thanks for the info
Old 10-20-2009, 03:40 AM
jd2518's Avatar
fob??
Old 10-20-2009, 07:55 AM
mblouir's Avatar
Originally Posted by jd2518
fob??
Not sure if all F150s come with it now, but the keyless entry controller.
Old 10-20-2009, 10:44 AM
Tornadom's Avatar
That was one of the first things I did after installing my HIDs.
Old 10-20-2009, 08:01 PM
WVMountaineer's Avatar
Too bad you can't disable the headlights but leave the remaining perimeter lights on.
Old 10-20-2009, 09:07 PM
Labnerd's Avatar
On my 2004 SCrew all I have to do is turn the dash light dimmer to off and they don't come on. It just doesn't work to light up a pasture at night when hunting. Works for me.
Old 10-21-2009, 08:30 PM
subnoob's Avatar
Red face
Not working for me. I've tried but don't hear a horn chirp
Old 10-21-2009, 09:25 PM
LoneRanger93's Avatar
Might sound wierd but... is there a way to not have the headlights come one during this?
i.e. just the running and interior lights?
Old 10-21-2009, 09:29 PM
mblouir's Avatar
Saw the post before you edited. Ignition ON means you flip the key to turn the accessories on, not turn the truck on. The truck will not start during the entire process.
To get just the running lights instead of the headlights you'd have to do some separate wiring. Not sure where it's located but wherever the control box (or whatever it is) is inside the truck, it's hooked up to the headlights so that when you unlock it, it triggers the headlights. I'd think you would have to hook it up to the parking lights wire instead of the headlights wire. Someone with more electrical knowledge will answer, hopefully. That's just what I would guess.
Old 10-22-2009, 01:50 AM
subnoob's Avatar
Red face
[QUOTE=mblouir;3934093]Saw the post before you edited. Ignition ON means you flip the key to turn the accessories on, not turn the truck on. The truck will not start during the entire process.
Excuse me for being redundant, but one click forward(radio on) or two (warning lights, dash lights on)
Old 10-22-2009, 02:05 AM
mblouir's Avatar
Hey that's what this thread's here for. Two clicks. Turn it as far as it will go without cranking it.
I recently had to reprogram my keys after installing an alarm and PATS bypass. The red LED on top of the dash will turn on for a few seconds with the ignition in the ON position. That's another way to tell.
Quick Reply: How to: Disable Perimeter Lighting (Save your HIDs!!)
