1.5" leveling kit questions. Help needed..
is this thread like noob central?
the reason you dont see many people leveled with 35's (4x4) or 33's (2x4) is most people usually ended up with new rims which wont allow those sizes, and we have alot of older people who dont want a large tire on to begin with, they just want a more leveled stance.
louisiana lariat, one problem with your theory on measure twice, install once is sometimes you net more than the 2" or 2 1/2" which you bought. i have heard many people getting up to 3" with the 2 1/2's. its a good start to get close, but dont be disapointed if you do end up a little nose high or ended up a little low. different trucks will vary depending on many factors.
After reading all the posts I think what everyone is suggesting is 2.5 spacer on the front should do it since no extra weight will be on the rear - Auto Spring seems to be most recommended and can get it off e-bay - and be sure and get an alignment afterwards (always after any suspension work).
My question is does it change the ride comfort at all - I bought this truck because of it and really don't want to mess it up nor do I want to wear out the front end pre-maturly. Also looking for suggestions on tires and tire size - need something a little more agressive than the Perelli's but not loud or rough - OH yes - truck has 20" rims.
thanx -
Leveling spacers do put the front end parts at higher angles, causing extra wear. If this is a big concern for you, look into the Bilstein leveling struts. They level the truck without using a spacer, therefor keeping the suspension angles lower. Disadvantage is cost. An Autospring kit is $69. Bilsteins are around $400 for all four struts and shocks.
As far as tires go, look into the BFGoodrich All Terrain in a 285/55R20. They will fit a leveled truck with stock 20s nicely.
whats the difference between going 2" with a spacer and going 2" with bilsteins? nothing. they will both do the exact same thing to your front suspension and give the exact same angles (assuming their both exactly 2"). only way to prevent "bad" angles is a subframe to drop the whole front suspension down farther.
explain?
You are correct. Both the spacers and the leveling struts will increase CV axle and balljoint angles.
Basicly, if you need shocks, the Bilsteins are a great option to serve both purposes. I will most likely end up replacing my shocks with the Bilsteins and removing the AS spacer I currently have installed.
Yes. Stock shocks with the Autospring 2.5" spacer kit. Truck is a 2005 with 63,000 miles. Well over due for shock replacement.
Video of a few different angles of the truck with 35x12.50R18 BFGoodrich Mud Terrain KM2s.
http://www.youtube.com/watch?v=_m1Lazc4YcA
AAL will solve your issues.
