cruise control?
ya everything else works, brake lights work the right side of the steering wheel works it is just the left side and cruise control dont work... and hasn't since i have owned the truck...
I have a similar problem, but once in a while it will actually engage but will shut off (the cruise not the engine) after a brief period. 1-2 minutes.
In previous vehicles, when you press the cruise button, a light on the cluster comes on indicating it was active. Then you press the set button and yer good. When I press the "On" button, no light is evident to let me know it is active. Then "sometimes" if I press the set button, a small light comes on showing it is on and working.
The outside temp gauge shows 99 when it's really 77, but I bet that's another issue.
Any thoughts on this?
Found it: https://www.f150online.com/forums/in...ay-screwy.html
on
...<snip>....
...<snip>....
Did you install LED brake lamps anywhere ?
Check if the brake switch / shift interlock is adjusted too close to the top, or it could be bad.
The shift interlock switch should not be 350.00 to replace, that is just crazy.
The switch has 2 circuits to it, and should be the same one as the Stoplamp switch for ~ 17.00.
It is right on the brake pedal.
If this is not the case, either the VSS ( or if 4x4 the output shaft ) sensor might be having a problem.
Quick test, have someone stand behind the truck, looking at the CHMSL, and wiggle the brake pedal side to side, to see if the light flashes.
Take a look at your owners manual, there is no CC on indicator in the instrument cluster, what you are describing is normal operation as far as the cluster indication goes.
I DID find this in searching through google however:
See if you can shift out of park without putting your foot on the brake pedal. If you can its the shift solenoid killing the cruise control. I have the same problem.
I am in fact able to do just that. So I'm curious where this solenoid is and if it's something I can replace myself. Just to rule it out.
I apologize for the lack of knowledge in this area. This is my first full size truck. Aside from this issue, i'm diggin it.
on
There we go, good trouble shooting
The shift interlock could be the interlock switch on the brake pedal switch or the shift interlock solenoid itself.
2004 FX4, I assume it is a column shift ( or is it a flow through console ) ?
On the column shift it is on the side of the column, on the flow through it is next to the shift lever.
Obviously this is under the trim panels
- cup holder / shift trim panel on the flow through
- behind the knee panel / anti submarine panel on the column shift.
Here is an old thread on the topic, with similar symptoms, and location info on the shift interlock switch ( his cure was not the interlock solenoid ) .
This member replaced the shift interlock switch ( also the brake pedal position switch ) on the brake pedal. P/N : 4L3Z-13480-AA
https://www.f150online.com/forums/el...k-problem.html
For 17.00 + Shipping and an easy swap, this might be a good route to take 1st.
PS: No need to apologize for the lack of knowledge in this area, that is why we are here, to help each other out
