Screeching Window
Old Aug 25, 2009 | 02:40 PM
jeffsilver2004's Avatar
Screeching Window
This is a strange problem. I have a 2004 F150 extended cab.When I put my drivers side window down, power window, I hear a screeching sound. The drivers side is the only one to do it. My friend who also has a 2004 F150 has the same problem. I took the truck to the local dealer and low and behold they didn't hear anything. Any help would be appreciated.
Old Aug 25, 2009 | 05:47 PM
jntibs's Avatar
I too have this problem, but no answers. All I can figure is that is has something to do with the weather, because at least on my truck, it only happens when it's hot and humid. I have an 04 scab, but a buddy of mine has a 04 screw and his does it too, but only on hot and humid days.
Old Aug 25, 2009 | 06:35 PM
Penguin86's Avatar
my window was screaching and then stopped working the pulley on the regulator went kaput
Old Aug 25, 2009 | 07:46 PM
countyboy04's Avatar
Sounds like your should be getting ready to replace the window regulator.
Old Aug 25, 2009 | 07:56 PM
VTHokieF150's Avatar
My '06 also makes that noise on only the driver side window. It goes up and down fine and it only makes the noise when the truck has been sitting in the sun on a hot day. Haven't taken the time to look into it since it only does it in those conditions, but would be nice to know what it is.
Old Aug 25, 2009 | 08:20 PM
Ftruck05's Avatar
pop off the door panel and grease up the cable/pulleys. Both of my windows did that and I took apart the passenger side and greased everything that moves and now it does not squeak/screech.
Old Aug 25, 2009 | 08:40 PM
Justin_w32's Avatar
Mine does it too, so does my buddys 06
Old Aug 25, 2009 | 08:54 PM
johnnyd2723's Avatar
Here's some more info
https://www.f150online.com/forums/20...squeeking.html
