Lifted 2WD,S
the spindles are different. and so are the struts for the coil-over. the 4x4 struts are 1" taller...and a 4x4 has a 1 5/8" (2" roughly) block in the rear
a 4x2 lifted 6" will be 1" shorter up front and about 2" shorter out back than a regular 4x4 lifted 6"
That is really the same point I want to make. Put in some 4x4 struts and a the 2" block and only the spindles are different. Now the lifted 6" 4x2 will sit at the same height as a regular 4x4 lifted 6".
A full lift kit (say 6") will give 6" in the front and 3 or 4" in the rear depending on the kit. AFAIK there are only 3 full suspension lifts for 2wd's, Pro-Comp, Fabtech, and Skyjacker. Here is the links to the install instructions.
pro-comp http://www.explorerprocomp.com/PDFs/is/52205MX.pdf
fabtech http://www.fabtechmotorsports.com/pd...on%20Sheet.pdf
skyjacker http://www.skyjacker.com/image/search/pdf/F4621STKS.pdf
