Who has the highest mileage 5.4 3V?
Just rolled over to 160K yesterday...towing a 6 X 13 cargo trailer up I5...I have put 2K miles on it in the last 3 weeks...
I saw 103 while towing and the temp gauge never moved from its normal spot...I did only get 270 miles on the tank of gas...
I know I am on borrowed time...
I've got an 05' Screw 4x4 XLT with Roush appearance package with 188894 miles on it. I bought it with 186,000 for $7500. The p.o. did vct sensors ,timing chains,tensioners, and guides. It makes cam phaser noise after the oil gets warm, and needs a spark plug change. I used to be a tech and can handle the job myself luckily. The other bad part is that I notice it uses some oil so I don't know if the rings are going or valve guide seals.
"Ok guys I just hit 24k, but I'll let you know when I break 1.3million"
17 years later:
UPDATE: Just hit 48k guys!!! Bout to throw the 2nd set of Terra grapplers on! (Nitto discontinued this tire 12 years ago, but a buddy of mine has 1 set left) YAAYYYY
Hahaha sorry, sarcasm...
260,000 plus
i have 260k plus on my 2004 f150 5.4 3v Crew cab 4x4 lariat.
Mostly original except:
batteries
brakes,
alternator,
plugs,
just now put on Chinese ebay coil on plugs,
shocks,
shifter interlock switch,
upper control arms (didn’t need)
many hail damage events,
many deer hit,
one exhaust bolt leaked.
just put drivers side power window regulator and passenger rear. Easy and cheap.
ticks like crazy.
Will put on cam phasers, oil pump, tensioners, and chains myself.
i have phasers unplugged now.
4H does not show on dash. Will replace 4x4 shift solenoid soon.
getting little paint bubble in rear cab corners. Must be rain leaking from third brake light?
doesnt use oil or smoke. Oil filter base leaks.
Needs lower control arm bushings. Pops like crazy on pot holes.
a tough truck.
batteries
brakes,
alternator,
plugs,
shocks,
many deer hit,
ticks like crazy.
a tough truck.
I have an '04 with 236,500
