***OFFICIAL*** Saleen Wheel Club
Old Dec 18, 2010 | 06:27 AM
  #121
Nice, JP2!!!
Old Dec 19, 2010 | 05:36 AM
  #122
Jetpilot2's Avatar
Originally Posted by Stealth
Nice, JP2!!!
Thanks Stealth!!
I can't wait to get home to ACTUALLY see it!
Old Dec 28, 2010 | 12:04 AM
  #123
pmason718's Avatar
Originally Posted by mixedbreed
i had locks from teh previous owner.
well as you all might know, i sold my truck, had to return it to stock but, i did sell the saleens this weekend to a guy in Cali that has a 2011 HD with the 6.2 on order and they are going on that. so maybe you will see them on here again!!!
And this is what I'm thinking of doing, lol. I'm thinking of selling my truck for the Ignot Silver HD and re-powder coating my wheels, just don't know what color as of now.
Old Dec 28, 2010 | 12:25 AM
  #124
bankrpt's Avatar
could you put the back wheels up front and the front wheels out back then the front wheels wouldnt stick out and the back would might look better who know lol just a thought?
Originally Posted by pshatt01
Here is some more to show you what I am talking about.
Old May 14, 2011 | 09:19 PM
  #125
bigb989's Avatar
Finally joined the club. Little concerned I put what I though the 44 on the front. Seemed a little wider than the others. The place I bought them from stated they were a offset 2x44 and 2x30 prob is the front stick out a bit. They don't seem flush. Back seem pretty flush. Put them on my 2010 platinum. I know dumb. But the 44 is suppose to be wider? Just seems like the wider should be in back. Let me know.
Old May 14, 2011 | 11:10 PM
  #126
Fke Snk's Avatar
Cell phones pics...womp womp. I need to take some good ones
Old May 15, 2011 | 03:44 AM
  #127
mixedbreed's Avatar
Good looking truck!!!
Old May 15, 2011 | 08:45 AM
  #128
Jetpilot2's Avatar
The 44's go on the front and the 30's on the rear if you want them like they came on the Saleens. If you look at the lug nuts, they will be inset further on the 30's (rear) and very close to the surface on the 44's (front). You can see this on my pics in post #120.
The problem with the "sticking out" is a matter of having the wheel opening moulding or not. I'm willing to bet if they are "sticking out", you don't have the fender trim. Even you go with 44's on all corners, the rears will be close to flush, but the fronts will still stick out slightly.
Here is with and without trim.
Old May 16, 2011 | 04:26 PM
  #129
bigb989's Avatar
thanks for the info. i had them on backwards. got them changed up. dont stick out as far. look good could stick out a little due to tires. got the grabbers. little wider. got some lock lugs and only prob is the front ones are not flush like the reg lugs. i guess beats getting them ripped out.. oh well FML for nothing working but
for some reason i cant uploand any pictures it keeps asking for a URL address. anyone know what else i am doing wrong.
Old May 16, 2011 | 06:20 PM
  #130
Jetpilot2's Avatar
You can't post pics directly, but have to use a photo hosting site such as Photobucket; upload your pics to your album at the site, then copy & paste the URL for that particular pic and it will show up in the post as mine did.
Old May 17, 2011 | 11:55 PM
  #131
daggysvo's Avatar
Is it just me or are the 30 and 44 numbers in reference to offset and not how wide it is?
If you had 44mm of offset it would tuck under a bit more. I have no clue what else a 44 or 30 could be. Sure as hell isn't a width. Those rims looking like 10 inches wide or 255mm.
There was a post here that mentioned buying all 4 rims with a 44 offset and using a 1/2 inch spacer. That makes a ton of sense if you want to ever rotate the tires. Just use good spacers and make sure you have the right lug nuts. Kudos for coming up with a good thought.
Old May 18, 2011 | 03:07 PM
  #132
Jetpilot2's Avatar
You are correct, the numbers refer to the offset. And again, you are correct; the 44mm "tuck" or set in 14mm (approx. 1/2") more than the 30's.
If you are going to use all 44s, you wouldn't want to use the spacer on the front, only the rear to essentially give you the original 30mm offset.
BTW, the wheels are 10" wide.
Old Jul 10, 2011 | 02:28 PM
  #133
Percy811's Avatar
Old Jul 10, 2011 | 06:27 PM
  #134
Jetpilot2's Avatar
Percy,
You're halfway there; now just lower it a bit and you're all set!!
Old Jul 10, 2011 | 07:27 PM
  #135
mixedbreed's Avatar
nice Percy, just level it. saleens almost make me wish i still had the 150.... till i drive my 350...
