pop..pop.....smoke?
Old Jul 21, 2009 | 03:14 AM
05bltfrdtough's Avatar
pop..pop.....smoke?
I was driving on the interstate tonight and noticed my exit was coming up... I began to accelerate to pass a semi and while the truck down shifted it was like the clutch was slipping and the rpm's continued to go up (this has happened a couple times recently) then there was three pops from the engine compartment and I smoked out the cars behind me (first time). Everything seemed fine after this... any thoughts on what this could be? I have just hit 65,000 miles it is an 05 Supercrew.
Old Jul 21, 2009 | 07:59 AM
05supercrew's Avatar
Any cells, it could be an injector.
Old Jul 21, 2009 | 08:33 AM
05RedFX4's Avatar
What engine? If its a 5.4 it could be the injectors.
Old Jul 21, 2009 | 02:16 PM
Yes it is a 5.4. If it is the injectors, do they need to be replaced, or cleaned?
Old Jul 22, 2009 | 12:57 AM
How do I go about cleaning them, just pour the additive into my tank or is there a more efficient way?
Old Jul 22, 2009 | 01:25 AM
Bigs125's Avatar
There have been a few threads on here about injector problems. One is listed below but there are some more if you do a search. Seems like it's a relatively common problem on your year truck. Best of luck getting it figured out!
Injector Problem
Old Jul 22, 2009 | 01:34 AM
Peladho's Avatar
As I understand it the 05 has injector issues or some of them do I had one replaced in mine
I think its more than just a cleaning you need, but i was told that there is a 110000 mile warranty on the injectors and spark plugs I think
Was the smoke black or gray ?
Old Jul 22, 2009 | 01:43 AM
Thank you Bigs, and Peladho I will look into that warranty, and I have no idea what color the smoke was it was around midnight the only reason I noticed smoke was the headlights behind me got hazy.
Old Jul 22, 2009 | 09:43 AM
120K and no spark plug warrante.
