Quik question about the key pad....
Where do I find the combination for my key pad? I've looked under the dash and couldn't see it. That's where the code to my Gen. 2 Lightning was but can't find it on my 04 screw.
It's behind the back seat on the bulkhead.
That is the only way, the first time. You can then tie the clips back with zip ties so it can be removed easier. You can also go to the dealer and have them hook a computer up and read it for you.
Do a search for "Backseat Removal".
Locate the plastic cover where the shoulderstrap position is for the rear seat drivers side passenger. It's that box sitting on top of the seat back. Remove the little plastic panel on top of it and remove the two nuts inside. Let the box dangle and lift up on the entire seat back. It's held in with clips that you just lift the seat back off.
