Wicked metal on metal sound under my truck
Old Jun 29, 2009 | 04:39 PM
XLT-FX4's Avatar
I had a bad left front wheel bearing on my truck a few months ago. No noise in 2wd, but in 4x4 it hummed pretty loud. When I jacked it up the thing was wasted. I could move the tire up/down/side to side q lot. I was surprised it hadn't been making all sorts of noise or driving funny.
The bearing/hub cost me $160 from RockAuto and it took me just about 45 minutes to replace it...very easy. Just some random thought...
Old Jun 29, 2009 | 05:23 PM
mcrob's Avatar
I had the same noise. it sounded like I was dragging a rake down the road. I had the solenoid on the firewall changed and it has been fine ever since. Ford has a TSB on this. It cost me $40 here in Canada, so it's probably about 50 cents in the States.LOL The new ones are sealed better so water doesnt get in
Old Jun 30, 2009 | 08:26 AM
Trogdors4x4's Avatar
I did the solenoid, I did the actuators recently. This sound is coming from my 2 front wheels. I took a video with my camera I just cant post it here at work.
Old Jun 30, 2009 | 11:33 AM
06yz250f's Avatar
Originally Posted by Trogdors4x4
It comes from the front of the truck. Could it be muffler bearings? Ive had the truck for almost 2 years now and its done this since I had it but it has just become worse and worse. I need to take it in I guess.
it could be, most aftermarket mufflers have the bearing deleted to free a little more flow up and just takes out one more variable that will break.
Old Jun 30, 2009 | 08:01 PM
Tbird69's Avatar
That the biggest advantage to the aftermarket mufflers.
Old Jun 30, 2009 | 09:41 PM
jntibs's Avatar
Originally Posted by Tbird69
Based on your description, it sounds like the muffler bearings are shot.
Old Jun 30, 2009 | 09:59 PM
Yeah I actually don't even have the muffler on there. I cut it and did straight pipes.
Old Jul 1, 2009 | 11:49 PM
purpony's Avatar
my lifted 04 just started making this exact noise! I made a hard right onto a side road and the noise started. I pulled off on another road and hopped out to investigate. Couldnt find anything so I started driving again. About a min later it started again. Stopped, put it in reverse and it went away. Pulled back onto the road and headed for home. About 5 miles down the road and 2 miles from home it started again... sounds extremely bad, like the drivetrain is about to fall out from under the truck. I pulled over and when i slowed down to almost a stop, i felt and heard a clunk, and it it went away. couldnt really tell where the noise was coming from.
Old Jul 2, 2009 | 10:07 AM
Mine is going in next week to get scoped out I'll let you know what I come up with. I'm getting the truck in selling condition and that sound has to go.
Old Jul 2, 2009 | 11:29 AM
inthezone's Avatar
could be alot of things raise each corner independantly and rotate tires to narrow it down.
u joints,bearing asemmbly ,ect...
Old Jul 2, 2009 | 12:08 PM
NoLongerJeepin's Avatar
Great prices on muffler bearing right here http://kalecoauto.com/index.php?main...products_id=10
If it ends up being brake related, you might also want to replace your brake lines with some premium cross drilled brake lines http://kalecoauto.com/index.php?main...&products_id=1
Old Jul 2, 2009 | 09:52 PM
Tbird69's Avatar
Where was this info a year and a half ago when my bearing went out? I paid 4 times that from Ford!
