just blew my trans
What type of truck do you have? Your bio is empty so we can't assist you.
Do you drive in crazy harsh desert conditions like extreme heat and/or dusty offroad conditions? Do you have a lift like a 6" Pro Comp with oversized tires? These will be hard on a transmission.
ok so the truck will drive but it pours out oil from what looks like either the pan or just above the pan on the passenger side
any ideas? if i need a new trans, where could i get one cheap or at least something a little better for a decent price? tasca has them for $1,600ish
ill probably do the swap myself, should i pull it out tomorrow and try to inspect it for damage or possibly a bad seal?
Oil or trans fluid?
Well I have 35's and tow often. I got the truck with 65k on it (I installed the lift) but dont know how the previous owner treated it. The constant shifting in and out of overdrive at highway speeds killed me. I have 3.73s and will eventually get it regeared.
Going to the grocery store and back isnt exactly stressful.
