Cannot shift out of Park. (2004 FX4 SCREW)
Old May 20, 2009 | 01:56 PM
AAK625's Avatar
Exclamation Cannot shift out of Park. (2004 FX4 SCREW)
Hey guys, hope everyone's doing well. I can no longer shift out of Park without depressing this white plastic circle on the left side of the shifter (Cupholder housing removed on flow through).
Any ideas?
Thanks guys,
Anthony
Old May 20, 2009 | 02:03 PM
squirtbottle09's Avatar
Hmmm, until someone comes up with an answer I would leave the truck in neutral and set the parking brake, lol.
Old May 20, 2009 | 02:17 PM
birddog_61's Avatar
I bet its the sensor that detects when you press the break pedal.
Old May 20, 2009 | 05:12 PM
AAK625's Avatar
Well, I've been manually pressing down this plastic release that lets the stick, shift. I have the housing with the cupholders, off right now.
How do I fix this sensor?
Old May 20, 2009 | 08:10 PM
kingfish51's Avatar
Check and make sure the brake pedal switch is working. See if you have brake lights when you depress the pedal.
Old May 20, 2009 | 10:14 PM
AAK625's Avatar
I do have brake lights. Anything else?
Old May 20, 2009 | 11:03 PM
adaniels88's Avatar
check the fuses, there should be one specific to the shift interlock.
Old May 20, 2009 | 11:47 PM
Tbird69's Avatar
It sounds like the relay for the brake shift interlock, they've been known to fail from time to time.
Old May 21, 2009 | 12:17 AM
AAK625's Avatar
Ford said it would cost me $400 plus labor to replace the shifter!
Old May 21, 2009 | 02:41 AM
Ymustuh8me's Avatar
Isn't there a actuator that moves when you press the break? If there is that could be bad.
Old May 21, 2009 | 12:55 PM
AAK625's Avatar
So, am I screwed?
Old May 21, 2009 | 01:04 PM
dsq3973's Avatar
Yes my F150 used to have a very audible click when I pressed on the brake to shift out of park. I had the same set up as the OP does with the flow through console.
Old May 21, 2009 | 02:13 PM
4X4 4 LIFE's Avatar
AAK625
Look under the dash where the brake pedal is you should see a black switch with 4 wires coming off of it and a yellow clip. This is you brake pedal switch it tells the shift interlock solinold that you are pressing the brake to shift out of park and it also will cancel cruise control when you hit the brake. If you put your hand on the switch you will feel that it pivots up and down. When you move the switch up and down with the engine running the little white button in your console should move down. If this happens your brake switch is bad and need to be replaced.
Old May 21, 2009 | 02:52 PM
kingfish51's Avatar
He already stated the brake lights come on, which means the switch is good.
Old May 21, 2009 | 03:23 PM
BoomTik's Avatar
I had to replace this part in my wife's 2002 Ford Escort ZX2, It was the shift interlock selenoid. Not to bad to replace but I've never changed one in the new F-150's so I'm not sure how bad it would be. The part through Ford was about $115.00.
I also asked about a Fuse and a buddy of mine who worked in the body shop at the dealer said that they always just replace the selenoid in the service dept.
