Need Help (engine)
Old Apr 19, 2009 | 11:13 PM
nickolas.morgan's Avatar
Exclamation Need Help (engine)
Ok well the snow in alaska is about gone so i decided to give my truck a good wash!! so the net morning i turn on my truck.. and its like a loud noise almost like a hissing or sucking sound and it gets louder when i press the throttle!! There are no obvious problems i can see of feel as of now!! i do have a intake but i have had it sense 40k miles and i got 117k now!! and i have never heard that before.. my truck used to purr like a kiddy but not its embarrsing me!! someone please help!!
Old Apr 20, 2009 | 12:29 AM
NoLongerJeepin's Avatar
Did you disconnect anything? Any vacuum hoses come undone? Could it be your belt slipping?
Old Apr 20, 2009 | 12:36 AM
i didnt disconnect n ething.. i mean i did wash the crap out of it with a pressure washer.. so i could check that... but a belt slipping would make that sound??? sounds stupied but whats a good way to check the belt
Old Apr 20, 2009 | 12:38 AM
Ummm yeah that might do it
Go through the engine and check every connection you can find and make sure they don't have any water in them and that they're on tight.
Old Apr 20, 2009 | 12:41 AM
well ***** i hope thats it!!
Old Apr 20, 2009 | 01:20 AM
well just got back from the truck! and the engine bay is dirty as hell.. so i did a once over to see if the connections were lose and they were good... the sound is still there it seems like its coming from the bottom right pulley area??? im not sure how to properly check the belts tightness.. u said it might be it?? but i really cant think of what it is.. so tomarrow ima clean the engine bay really well and start all over again?? do the pulleys have to be lubricated in some way?? kinda soundin like that could be it??
Old Apr 20, 2009 | 01:41 AM
freekyFX4's Avatar
Either make a video of the truck making the noise and post it on here or just take it to a shop and let them figure it out.
Old Apr 20, 2009 | 09:08 PM
so today i took the truck to the ford house.. me and the mechanic looked it over and then we run it for a min and he catchs the lower idler puller is wobbling back and forth!?!? so im guessing thats my problem.. but what would make it get to the current state that its in?? how did it get to this?? normal wear and tear??? did i do something to cause this?
Old Apr 20, 2009 | 09:11 PM
Sounds like the pulley bearing wore out. They tend to do that over time.
Old Apr 20, 2009 | 09:18 PM
hey stealth.. so that could be causing that sound... reason why im soo frickin worried is becuase i leave to go "downrange" in 1 week and need to get it fixed asap for the wifey so she aint worried about it
Old Apr 20, 2009 | 09:23 PM
Yes bad bearings make odd sounds, and I would definitely change the pulley.
Old Apr 20, 2009 | 09:35 PM
... so re tightening wouldnt really be a good idea..just a short temporary fix???
Old Apr 20, 2009 | 09:37 PM
It being loose and a bearing being worn out are two different things. You could give it a try though. Hard to accurately diagnose the problem from Texas.
Old Apr 21, 2009 | 08:33 PM
Ok so i come back to this thread to put it to rest.. took it to the ford house here in alaska thinkin aww man ima get raped on charges and what not.. so the problem was the lower idler pulley and bearing.. so they fixed it and came to pick it up and the bill was 60 bucks i was like WOW!!! sweet!! did that work and clean the crap out of my engine bay for me for free.. looks like it just came off showroomfloor!!! so i am very proud today to be a ford owner!!! hahah and would like to say SEEKINS FORD IN FAIRBANKS ALASKA TAKES CARE OF THERE PEOPLE!!!
Old Apr 21, 2009 | 09:34 PM
That's great!!!
