Need some of your ford tech's help...
Old Apr 9, 2009 | 07:17 AM
FATHERFORD's Avatar
I need to find out the wiring info for the fuel pressure sensors of an 04 5.4 3v and a 06 5.4 3v. The 04 is a 3wire and the 06 is a 4 wire.
I can check All Data later this evening, but it would be nice if one of you ford techs have that info infront of you.
I had to swap sensors because fuel rails are different to make my blower setup work.
Edit: This is Just words to be used for searching..
Fuel Pressure Sensor Rail Wiring schematic Diagram FATHERFORD Saleen Blower Supercharger JDM
Old Apr 9, 2009 | 08:16 AM
Quintin's Avatar
.....removed.....
Clear as mud...hang on, lemme resize them.
Old Apr 9, 2009 | 08:21 AM
Quintin's Avatar
Old Apr 9, 2009 | 08:23 AM
Quintin's Avatar
The second picture is still kinda cruddy. "H" is ground from pin 58 at the PCM, and "G" is VREF from pin 57 at the PCM.
Old Apr 9, 2009 | 08:27 AM
FATHERFORD's Avatar
So it looks like the 4th wire goes to pin 19. I wonder if that is unused on the 04 computers?
Old Apr 9, 2009 | 08:35 AM
Quintin's Avatar
It is.
Old Apr 9, 2009 | 08:48 AM
FATHERFORD's Avatar
Thank you sir!
Now I just need to get the connector to it.
Originally Posted by Quintin
The connector book lists this for a mass air sensor or TPS, but looking at the picture in the book and in the wiring diagram, this looks like it.
Try a 3U2Z-14S411-UA. The Motorcraft number is WPT205.
Old Apr 9, 2009 | 08:50 AM
Quintin's Avatar
Welcome.
