Back seat
Old Mar 29, 2009 | 04:23 PM
  #46
pmason718's Avatar
I didnt use one. My hands are small enough or should I say that my arms are small enough to reach around and pull the tap back
Old Mar 29, 2009 | 04:53 PM
  #47
VetCoach's Avatar
I could not get my hand on tab so will have to use screw driver
Old Mar 29, 2009 | 05:36 PM
  #48
jalichoacan's Avatar
ima try and fit my hand.. if not ill have my wife do it
Old Mar 29, 2009 | 06:36 PM
  #49
bigdog87's Avatar
Well, lucky. I don't have a wife, and my girlfriend isn't here!
Old Mar 30, 2009 | 01:07 AM
  #50
Indo's Avatar
so we dont need screwdrivers??
Both my neighbor and I were able to do it without screwdrivers. We're both 6'1 and I'm 180, he was 225. Won't be all that easy but it is definitely do-able. It's hard to explain exactly how to get the clip off but once you feel around again and again you'll finally get it. Once you do, the other side takes only a minute or two and finally, once it's all the way off it makes even more sense.
Old Mar 30, 2009 | 01:10 AM
  #51
mSaLL150's Avatar
I also shoved my arm back there to reach the clips. Once I got the seat off, I zip-tied the clips so now I can easily pop the seat off and be to my amps in about 40 seconds.
Old Mar 30, 2009 | 01:46 AM
  #52
thanks guys.. i gotta give it a try again.
sorry bigdog, what can i do to help
Old Mar 30, 2009 | 09:18 PM
  #53
MnBrdDawg's Avatar
OK I was able to pull my back rest just by pretty much following these directions.
My forearms are to big to get my hands back there so I tried the screw driver idea.
I couldn't get it to go or I was just afraid of causing damage with how hard I was pushing.
So I took an old channel lock pliers and removed one side. With the angle it gave me I was able to push on the tab with little effort. Also I felt more comfortable using it bcz of the insulated round end I knew I wouldn't tear leather, fabric, or go thru my hand if I slipped.
All in all took bout 30min.
To bad my factory sub won't fit back there.
I haven't figured out how to post pics yet so check out my album. BackRestRemoved
Old Apr 1, 2009 | 09:05 PM
  #54
VetCoach's Avatar
I got it!
Wow...that was not easy but between all the tips and pics I finally got it and found the elusive door code I was looking for. Thanks for all the help! I will also be tie wrapping the clips back before I reinstall the back seat. Btw the T-50 does not need to be removed.
Old Apr 1, 2009 | 09:16 PM
  #55
oneminddoc's Avatar
What Dumba$$ engineer went to school for 4 years to come up with FUBARed Shi# like this design??????????????????????????????????????????? must have designed the plugs too;-)
Old Apr 1, 2009 | 09:35 PM
  #56
Old Dogg™'s Avatar
Here look at this...
can someone please help me remove my back seat!
ive seen posts on how to remove it.. i just cant put the screw driver on the clamp
Best seat removal link I have seen
