35" nitto mg + 2.5" as?
Old Mar 12, 2009 | 07:07 PM
Dstang's Avatar
Anyone know if this combo will work? I have 04 fx4 with 2.5 as and I machined some aluminum 2" blocks for the rear. I'm trying to decide which tires to go with either 33's or 35's....
Old Mar 12, 2009 | 07:10 PM
rojoscrewkab05's Avatar
35's
i have 35's on mine with a 3 inch spacer but im 2WD. i dont see why not.
mines only rubs when im really turning sharp
Old Mar 12, 2009 | 07:26 PM
ride_002000's Avatar
Aftermarket or stock rims? With the stock rims 35's will rub at full lock and with aftermarket rims they will probably rub on the valence or bumper. And 33 mud graps look pretty good on a leveled truck with most likely no rubbing.
Old Mar 12, 2009 | 07:35 PM
06yz250f's Avatar
for a 4x4:
stock rims= 35/12.5 max with slight rubbing at full lock
you cant go over a 12.5" tire or you will be asking for trouble with the stock rims. if you are using aftermarket wheels, they specs need to be as close to OEM as possible if you want to run 35's, if your getting a wheel that will push your tire out stick with 33s
with a mud terrain you might have a slight more rub due to the aggressive tread pattern on the side of the tire but you should be fine
if your using a 2" block on the rear, with the 2 1/2" spacer on the front you should sit probly perfectly level.
Old Mar 12, 2009 | 07:41 PM
Dstang's Avatar
Sorry i didn't specify, yes they are going on stock 18's, i like either sizes but would rather go with 35 mud graps, they're like $25 cheaper per tire
Old Mar 12, 2009 | 08:08 PM
06yz250f's Avatar
the 35's are cheaper than 33's?
Old Mar 12, 2009 | 08:25 PM
Dstang's Avatar
33x12.5r18 are $301ea and 35x12.5r18 are $281ea, these prices are from tires.com
Old Mar 12, 2009 | 09:04 PM
bigdog87's Avatar
What Load Range are they? That would cause a huge fluctuation in price.
Old Mar 12, 2009 | 09:41 PM
ATOM's Avatar
the reason being is 35x12.50-18 has been SO popular. (that's what i was told by a vendor, unsure if it's true)
Old Mar 12, 2009 | 09:47 PM
4x4LariatMan's Avatar
Been there, done that.
You'll need a 1/4" wheel spacer on the fronts to minimize the rubbing with 35's. OH NO! WHEEL SPACERS!? Yes, wheel spacers. I ran them for about 20K miles with no problems until I got my lift and 37's. Be sure and keep those suckers rotated cause they wear down quickkk. Also hope you like the sound of airplanes because you'll be hearing something like one every time you drive. Looks badass though!
