Edge...pull the trigger again?
Old Feb 18, 2009 | 10:05 AM
  #31
rms8's Avatar
You are correct in what you say. That just exceeds my needs. I'm not trying for optimum performance. The "mail order custom" I have is quite adequate for my needs.
Not going to argue your 87 tune which you say is equal to the OEM Edge's 93 tune.
You seem to drive A LOT (25K miles/yr), so that may indeed make up for itself, but I see about 7K/yr, so I would definitely not recoup my cost anytime soon.
SO, was the price of gas JUST KILLING you about 7 months ago?
Old Feb 18, 2009 | 11:13 AM
  #32
mxracer49's Avatar
Originally Posted by mSaLL150
The Edge sucks. Dont believe me? Throw your truck on the dyno and check out your A/F ratios...then tell me it doesn't suck.
Custom tunes FTW. $100 more is WELL worth it when you are talking about the safety of a $30k truck.
Can you tell us why it sucks?
Are you talking about a stock truck with an Edge?
Are you talking about a stock truck with aftermarket exhaust with an Edge?
Are you talking about a stock truck with CAI and exhaust with an Edge?
Any other mods?
Which motor? 5.4 or 4.6?
What elevation was the dyno done at?
What tune was being used? 1,2, or 3?
What year was the truck?
Just way to many variables to make that broad of a statement without some sort of explanation. Thanks
Old Feb 18, 2009 | 01:27 PM
  #33
Rambo's Avatar
How is the Edge just a stock tune when there are 3 different levels and various CUSTOM options that you can CUSTOMize?
Old Feb 18, 2009 | 01:28 PM
  #34
rms8's Avatar
Please refer to this post :
Originally Posted by rms8
Make NO mistake, a so called "custom" tune is still a **** BEST GUESS *** tune.
BEST GUESS regardless of someones experience. Sorry, but if I was going to dump that much money for a tuner on my 45K truck, I would have it tuned the right way, not the Best Guess method. Of course, no one is talking 50HP gains here, the gains will be SLIGHTLY more than what a OEM Edge gives you. Definitely NOT worth the price IMHO.
If you really believe the rhetoric, then do it RIGHT by getting a DYNO tune. The "custom" tune CANNOT factor in all the REAL WORLD variables which take place, such as ambient temp, vehicle load, wideband O2 readings at ALL RPM levels.... and these change on a constant basis.
If you're going to spend that much on a tuner, DO IT RIGHT with a REAL tune which factors in everything!
Old Feb 18, 2009 | 01:31 PM
  #35
last5oh_302's Avatar
rms8,
I realize you've had your Edge for a relatively short time, but how are you liking it so far?
Old Feb 18, 2009 | 01:32 PM
  #36
mblouir's Avatar
The Edge is customizable, but it's not considered custom tuning. Custom tuning takes into account the modifications you've made to your truck. The easiest two examples I can give you are a cold air intake and exhaust system. Custom tuning will take full advantage of these modifications while the Edge does not.
Old Feb 18, 2009 | 01:34 PM
  #37
MercedesTech's Avatar
The Custom tunes are custom. Each one is different for each vehicle. Even if they have the same mods and are identical, they take into account where you are located and blah blah blah. It is 100% custom. Is it the best route ? No. Better then canned tunes ? Absolutely. With these custom tunes, you can take advantage of other mods you have installed, where the canned tunes cannot do this. Make up for CAI, exhaust, custom turbo or supercharger etc etc etc. Canned tunes do nothing for this. So, yes, they are custom. I don't know what your definition of custom is, but these tunes most dfeinately are.
So, you are not correct, but you have the right idea. Yes, they are custom, no they are not squeezing out every pony they could. You can data log if you want better performance. I am lucky enough to have great guys at a local tuning station (RPM Auto Services). They have a dyno, and can log numbers for me, so i can send off to Bill to dial it all in even more. On top of that, we are working on bringing Bill out here for some live tuning sessions.
You mention "dyno tuning" as the end all be all.... but an even better step, and FAR more exact is live tuning. So, by your standards, dyno tuning is only "best guess" tuning also. See, i can nitpick too !
mmkay, couple more of my pennies thrown into the pile.
Old Feb 18, 2009 | 01:43 PM
  #38
jreeder's Avatar
Take a look at www.powerhungryperformance.com and call Corey or Bill. There is a conversion fee of maybe $50? Then you pay for the tune, which is maybe another $50. At least that was what it was back when I did mine. I figured by saving at least 30 cents a gallon over 25,000 miles a year, I would recover my cost pretty quickly. It would have been worth it to me if I recovered no cost, it's that much better.
Also, I meant to ask what your gas mileage was like with the 87 performance tune. Did it go up, down, or stay about the same?
Old Feb 18, 2009 | 02:09 PM
  #39
Rambo's Avatar
Most people don't have a modified exhaust and intake, so these options would be of no interest.
  #40
rms8's Avatar
So, you are not correct, but you have the right idea. Yes, they are custom, no they are not squeezing out every pony they could. You can data log if you want better performance. I am lucky enough to have great guys at a local tuning station. They have a dyno, and can log numbers for me, so i can send off to Bill to dial it all in even more. On top of that, we are working on bringing Bill out here for some live tuning sessions.
You mention "dyno tuning" as the end all be all.... but an even better step, and FAR more exact is live tuning. Technically dyno tuning is the same as "custom tunes" but they get to see the results and change it later, if they want. Live tuning is live changes on the fly, far more accurate. See, i can nitpick too !
I think your semantics are a bit misguided.
What in the world are you trying to distinguish between a "live tune" and a dyno tune?
I have my race car Dyno tuned when ever I make a change. This entails strapping the car to a dynometer and connecting the various sensors to the car (knock sensors, wideband...) and running the car through the gears and to it's redline. The tune happens in real time so the changes can be seen, again, in real time.
Don't get much "LIVE'er" than that...LOL
A canned tune AND a custom tune are BEST GUESS tunes. Yes, a "custom" tune will get you more within the BALLPARK than a canned tune, but AGAIN, it's a BEST GUESS tune. Can't see how anyone can argue that.
If you have mods as you suggested (CAI, exhaust...), then a custom tune would be more beneficial than a canned, but will NEVER account for all real world variables.
If one spends the $$ and installs a power adder yet cuts the corners by relying on a "custom" tune, well, the foolish are soon schooled. I would NEVER EVER rely on a custom tune for any sort of a SERIOUS motor. A custom tune would work well until one can get around to getting the real tune, but I wouldn't push that go-pedal too hard too often....
If you simply bolted a SC'er on top of a factory motor, a "custom" tune would work fine most of the time, but if anything internally changed, or you want the most out of that high dollar SC kit, then there is no comparison regarding a true dynotune.
In the end, I would say that the EDGE alone is fine for a vast majority of users out there. If any of those users thought they may add additional products to their motor in the future (CAI, exhaust...), then the Gryphon would be the better alternative in the long run due to the fact that it can compensate better with the different engine dynamics once those aftermarket goodies have been installed.
I personally have no desire trying to turn my 6000lb truck into a racer. So in that respect the EDGE severs me well. It allowed me to alter my tire size and shift firmness. A side benefit is that the Level 2 setting is ideal.
That allows me to segue into last5oh_302 question:
Originally Posted by last5oh_302
rms8,
I like it. I enjoy seeing the true temps of the coolant, tranny and oil. I enjoy the slight boost you get from the Level2 setting, and of course, the ability to correct for larger tires is why I got it in the first place. The boost is very noticeable, especially considering the move up in size tire I went too.
Obviously the display is not as comprehensive as the display in my PMS tuner on my Mustang, but the vitals it DOES allow one to display are above and beyond what most would need, or even understand.
Old Feb 18, 2009 | 02:14 PM
  #41
06yz250f's Avatar
There was a short period after Bill openned his shop where he was selling custom tunes for the Edge. But, Edge realized they could lose their CARB license, so they worked out an arrangement with Bill. He no longer sells custom tunes for the Edge but can do an "exchange", for a Gryphon, and then sell the custom tunes. I was one of the few ended up with an Edge with Bill's tunes. I wonder if that makes it worth a lot of money?
my dad kinda has that, he gave my sister the gryphon case and his gryphon looks like a stock edge, except has the little dragon or w/e it is when it turns on.
x2 on not getting an edge and going for the gryphon, my truck broke down twice cuz of that dang POS. truck had less than 6k on it at the time and both almost caused me to get t-boned. i ripped that SOB out of my truck so quick and got custom tunes from VMP. had VMP for about 15k miles with not one issue yet.
Old Feb 18, 2009 | 02:18 PM
  #42
Good to hear. Have you tried level 3 yet?
Old Feb 18, 2009 | 02:22 PM
  #43
rms8's Avatar
Originally Posted by 06yz250f
...my truck broke down twice cuz of that dang POS. truck had less than 6k on it at the time and both almost caused me to get t-boned. i ripped that SOB out of my truck so quick and got custom tunes from VMP. had VMP for about 15k miles with not one issue yet.
LOL
Yeah, I'm sure that the EDGE is a "POS".
That's probably why they continue to sell thousands of them for several makes and models of vehicles, all because YOU had a problem with YOUR truck that YOU attribute to the "POS" Edge.
Old Feb 18, 2009 | 03:05 PM
  #44
rms8's Avatar
No.
Level2 is fine, and I don't want to put 93 in it. I suites my needs great! To be honest, I never would have got it had I not got the taller tires though.
Old Feb 18, 2009 | 03:09 PM
  #45
No.
I bought mine for the same reasons as you. I'll definitely be giving level 3 a try though. It only requires mid grade (91 octane) if you don't bump the timing. I'll probably only use it when I make my long highway hauls up north though, besides, gas is pretty cheap now. Level 2 sounds perfect for around town with the improved low end torque.
