Help me to figure out? ABS lit on steady!
Old Jan 13, 2009 | 11:54 AM
YOMAN's Avatar
My truck 04 supercrew.
Never has this problem before......when i started up the motor ( to go out for lunch from work) the ABS warning lit on steady- what does that mean? ABS is not working but is it driveable?
How to fix this? I do have scangauge 2 but it doesnt show up with codes .
What is the possible problem?
THANKS!!!
YOMAN!
Old Jan 13, 2009 | 01:39 PM
che22879's Avatar
Not all scanners will pick up abs codes. I have a buddy who owns a shop and he used his mac tools scanner on my 99 to do a driving test to see what the problem was. My rear speed sensor was bad.
Old Jan 13, 2009 | 01:51 PM
Stiffhorn99's Avatar
Mine was also speed sensor the the rear. Sensor gone bad.
Old Jan 13, 2009 | 02:02 PM
YOMAN's Avatar
yeah ? wheres that excalty location?? how much did it cost you ?
Thank you
YOMAN
Old Jan 13, 2009 | 02:08 PM
MercedesTech's Avatar
yup, I ould guess wheel speed sensor.
Truck is driveable. ABS doesn't work, so don't get intoa panic stop. If you do, pump your brakes, don't just slam them.
Turn truck off, wait awhile, turn it back on. Light stay on still ?
Old Jan 13, 2009 | 02:09 PM
YOMAN's Avatar
yes it came back on steady lit on.
Where is wheel senosor ?
HOw can i check ABS fuse? i would like to check it .
Thank you
YOMAN!
Old Jan 13, 2009 | 02:16 PM
you can check the fluid in the master cylinder just to be sure.
Wheel speed sensors are on each front hub, and one in the differential.
Old Jan 13, 2009 | 02:22 PM
SIK-06's Avatar
Thank you
YOMAN!
Mine was the speed sensor in the driver front. look under there and you'll see a black cable going behind the hub, in between that and the rotor. if you take the tire, brake caliper, and rotor off you'll see it. and if you follow it up under your wheel well you'll see a connection. I got mine at autozone for like $26 dollars.
Old Jan 13, 2009 | 02:31 PM
YOMAN's Avatar
front- that i can do it....the problem- how do i know which side is shot/bad ?
As for rear, is it INSIDE or outside of differential?
If its inside, do i have to remove the rear cover, rings/pinions etc ???
Thanks!
YOMAN!
Old Jan 13, 2009 | 02:45 PM
wrench007's Avatar
The rear speed sensor on the differential is where I would start first. Replaced many over the years. But that was a long time ago, they seemed to have a short life. I think one bolt and a connector to replace it. Also has an O ring to seal it. But now that I think of it, chafed or broken wires were most of the problems I had because of the hundreds of miles on gravel roads each day they had to drive on. 70mph on those roads tore up more wiring than you could imagine along with other problems.
If it was me I would find a shop that could pin point the cause. Might save you $. It's very posible a speed sensor on the front could be bad as well.
Item Part Number Description
1 — Output shaft speed (OSS) sensor electrical connector
2 N605771-S427 Output shaft speed (OSS) sensor bolt
3 7H103 Output shaft speed (OSS) sensor
4 — Turbine shaft speed (TSS) sensor electrical connector
5 W700005-S309 Turbine shaft speed (TSS) sensor bolt
6 7M101 Turbine shaft speed (TSS) sensor
Rear.
1 — Harness connector
2 — Bolt
3 2L373 Wheel speed sensor
4 — O-ring
Installation Note
5 2C189 Sensor ring
Removal Note
Old Jan 13, 2009 | 04:53 PM
YOMAN's Avatar
Oh man.....i was about to go home... The ABS lit is now OFF .
What should I do? to contuning to replace anyway ??
I m thinking, maybe order one part for front senors so i ll start with front driver, if the ABS still lit on, then i ll move to pass. side to test it ? yes its waste of time but thats only a way to find out.
or heck with it, order 2 fronts senors and 1 rear ??
Is it easy to repair ?
I m pretty good with hands.
Where can i order parts (reasonable price) online ford parts?
Thanks!
YOMAN!
Old Jan 14, 2009 | 07:04 AM
YOMAN's Avatar
any one? please? i was not sure what to do with ABS issue since its now off?
Maybe connection is loosing ?
I ll try to clean it but its friggin COLD outside...hehe
Thanks!
Old Jan 14, 2009 | 11:11 AM
It will come back on. Mine did that 4 two weeks before I got it fixed. Dont stress yourself out, go to the dealership, they will find out which one is faulty and change it. It cost me 100 and it was done.
Old Jan 14, 2009 | 11:48 AM
YOMAN's Avatar
YIKES!
I called local dealership, they want $117 for check up PLUS parts, labor! WTF!
I ll try local mech auto shop, maybe cheaper....
Thanks!
YOMAN!
Old Jan 14, 2009 | 04:57 PM
SIK-06's Avatar
Have you done a visual to see if one is damaged? if so when the light goes back on pull up to any local shop and they can read the code. I got my speed sensor from local parts store.
