Installed my 8000k HIDS
Old Jan 8, 2009 | 07:45 PM
ugacoop16's Avatar
For 130 shipped for both heads and fogs they are awesome...True plug and play digital ballast.. 55w for the heads and 35w for the fogs. These are the same ones that Freddytran has and I think we can both highly recommend them and their lifetime warranty.
Im loving how bright white they are with the tiny bit of blue mixed in.
Old Jan 8, 2009 | 07:49 PM
verifine-f-150's Avatar
looks good
Old Jan 8, 2009 | 07:50 PM
bigdog87's Avatar
Looks good, pics of where you mounted the ballast?
IDNC76's Avatar
looks great, they look like 5k
did you buy the relay ?
and they are truly plug and play, no splicin and dicin ?
Old Jan 8, 2009 | 08:00 PM
Matrix13's Avatar
I have the 2004 F-150 with the square foglights.
1. Should I go with 35 or 55 for the fogs?
2. The whole HID system has a lifetime warrenty? If the bulbs go out we can just send them in for a new one?
Old Jan 8, 2009 | 08:02 PM
ugacoop16's Avatar
yes they will and i dunno I would probably still go with 35w for the fogs
Old Jan 8, 2009 | 08:03 PM
ugacoop16's Avatar
The fogs where..I had to tap into the heads but that took like 10 minutes...And ya this camera made them look a little like 5k but they have a much bluer tint in person.
Old Jan 8, 2009 | 08:04 PM
Matrix13's Avatar
Sorry, couple more quick questions...
Does these ballast have the FM radio problem? And do I need to buy a harness?
Old Jan 8, 2009 | 08:08 PM
ugacoop16's Avatar
no it doesn't have a radio problem because they are fully digital ballasts and you should probably always use a relay harness..I ordered one to put on my headlights.
bigdog87's Avatar
I love my HID's, after hours, of looking, I still can not find a place to mount my ballast
Old Jan 8, 2009 | 08:11 PM
ugacoop16's Avatar
Honestly I zip tied mine to random places where they fit good near the headlights or fogs.. Just use a few zip ties for each and they will be secure.
Old Jan 8, 2009 | 08:13 PM
bigdog87's Avatar
I tried to find a place to use the mounting brackets and such, but just no luck, so I "rigged" it and just taped it, looks like ****. I may invest in some zip ties haha. Preciate it, I love your truck btw.
Old Jan 8, 2009 | 08:17 PM
ugacoop16's Avatar
Appreciate it man...Ya i would def do the zip ties rather than tape..It will hold much better and look better also...You can hide it easier.
Old Jan 8, 2009 | 08:29 PM
azmidget91's Avatar
passenger side headlight removed and looking towards radiator, there is a big bolt with a washer that aluminum bracket is not stock, but i used that bolt
passenger side headlight removed and looking down, used one of the bolts down there
where did you get the hids?
Old Jan 8, 2009 | 08:37 PM
mSaLL150's Avatar
The best spot to mount the foglight ballasts is right behind the tow hooks. There's a little slot where they fit perfectly.
