I just can't baby it any more - darn 10% ethanol: MPG
OK, I've read many threads with wild claims about 20 MPG and such. I can't see how. Is there a problem with my truck?
I have an '05 4x4, Supercab with 3.73 Ltd Slip, stock tires, stock 17" wheels, and a hard tonneau cover, with an empty bed. Truck has 43K miles.
I drive like a grandma, and it pisses me off to get avg of 12 MPG combined city/hwy. I don't sit at idle, and I don't do drive thrus.
Air filter is clean, oil changed regularly, tires inflated to spec.
The only thing I can think is the damn blended gas MN requires us all to use. It's 10% ethanol, I run 87 octane. Mileage was this bad in summer weather as well.
I did a trip this summer - 99% hwy on a tank of gas, and only managed 17MPG.
Thanks for any help, pointers...
Yeah I've been dealing with the same thing but i just gave up caring. I average between 11 and 13 mpg. no matter what type of driving situation. The best I ever saw was 14 on the highway driving 70mph non stop through an entire tank. When I towed a trailer from Detroit to Boston (loaded on the way there, unloaded on the way back) still the same mpg. Driving like an a$$ or like a grandma, still the same. Cross country trip loaded and unloaded, same. Got my big heavy wheels and tires, exhaust, k and n filter; still the same. Oh well.
I have gotten over 19mpg a couple of times when running the bigger tires and over the holidays going to the in-laws I got 20.7mpg with the stock tires. Most of the time I average around 15 with basically a 50/50 split of city and highway driving. My truck is a 04 supercab 4x4, 5.4L, 3.73ls, stock 265/75/18 Goodyears in the winter and 325/60/18 Nittos in the summer, with Edge Evo on lvl2 running 89 oct, Airaid Jr. intake, custom exhaust, Truxedo cover. My performance mods didn't affect my mileage at all, the only thing that made a difference is my 325 Nittos, they make my mileage go down .5-1.5 mpg from what I have found out.
Why does your truck get bad mileage, I can't tell you that. Each truck is different even though they may be identical as far as options, they will get different mileage. Maybe try getting the newest reflash from you dealership, or try fueling up with a different brand of gas. I know that if I fuel up at Kwik Trip I always see lower mileage numbers, so now I always go to BP, Sinclair, or Shell.
You will never get better mpg with 10%E unless you have Flex Fuel. I did some research using my own data and discovered that for a given distance, I ended up burning more gas running E90 than pure petrol (mpg*.90 vs mpg * 1).
Cool thing is, here, our corner stores (7-11) have finally got their act together and switched to only serving E free gas.
Think about it. Have you heard the reports about what the chit does to 2 and 4 stroke engines (like lawnmowers)? Cant be good for a non flex fuel vehicle.
Mine just turned 10,000 miles this morning, so I know it is "broke in". So, I agree with brocious03, I also gave up caring....it just won't happen...at least for my Gas-Guppy.
winter gas is a different blend which able the truck to start easier in cold weather, but results in worse gas mileage so this time of the year thats part of what your seeing. i personally average 10-13 city on my truck w/ my 35's. my dad w/ his stock screw 5.4 w/ a gryphon averages about 15 city and has seen 22 on the interstate going 65mph. on average he gets 17-18 on the interstate going faster
might be that mine is a Flex Fuel?
with decent gas and primarily city driving I used to get 14-15 mpg...and about 18 mpg with primarily highways jaunts in the local area
on 2 long 2,500 mile trips I got 20 mpg damn near each tank @ 70-75 mph with 2 adults, 1 kid and about 500 lbs in the bed.
wierd? you must be hammering that thing all the time
I'm getting a constistent 12.5-13 mpg with 100% city only driving. I drive 10 miles/day commuting to/from work...the speed limit is 20-35 mph the entire time with 6 stoplights
and there is plenty of heavy pedal driving on my part
