Question on leveling kit
Old Dec 31, 2008 | 04:29 PM
Drunkonjack's Avatar
I see these are sold in pairs . Do I need a pair for front and back ?
Or just one pair ?
do they go on front or the back ?
I guess this is more than one question But I'm a little new to the forum.
Old Dec 31, 2008 | 04:47 PM
Ace85's Avatar
Just one pair to level the front. If you want to lift the back as well they sell add a leafs or rear blocks. Go with Bilstein adjustables to level the front. They sell leveling kits that add a metal block that mount on to the top of the strut mount but the replacing the front shocks to level the truck will give you a better ride quality and the level look you want.
Old Dec 31, 2008 | 04:52 PM
Tylus's Avatar
leveling kits come in sets of 2. and only for the front.
if you want more height out back you can buy an Add-a-leaf or blocks
leveling kit = $80 (roughly) + install charge
bilstein leveling shocks = $300 (roughly) + install charge
the install charge on the shocks will be higher since the coil-over will require disassembly. these are both jobs you can do in the driveway though if you are a wrencher
buy what your budget can afford. the shocks are nice, but if you have good shocks already, IMO you are throwing money away.
Old Dec 31, 2008 | 05:13 PM
thirdgenbird's Avatar
i think every day i agree more with tylus
Old Dec 31, 2008 | 07:18 PM
Ballin STX's Avatar
Man I am wanting to get the bilsteins and have someone install them but I have gotten quoted at 800$-1100$ to order the shocks and intall plus alignment!!! I might as well buy a lift kit and install it my self for that kind of money!!!
Old Dec 31, 2008 | 07:22 PM
WOW ! that is some serious coin for shocks insatlled
Old Dec 31, 2008 | 10:18 PM
VTHokieF150's Avatar
Are you serious??? That is ridiculous!!!!!!! I'm pretty sure you can find a shop that would do it for much less. How much are the shocks alone if you order them online? When I first got my truck I had a local shop install a 2.5" leveling kit. It was a few years ago, but if my memory serves me correctly it cost me $180 for the installation of the kit and alignment. (I think it was $80 for the alignment alone... so $100 to install the leveling kit.) The Bilsteins shouldn't cost that much more to install.
Old Jan 1, 2009 | 12:02 AM
Why would you need a shop to install the shocks??? That's an easy job, even for the front coilovers. I can understand a shop doing the alignment, but that's only around $50 or so.
Old Jan 1, 2009 | 01:09 PM
Ballin STX's Avatar
I think my main pet peve is having to take apart the spring and shock and then putting the bilstein one in and then recompressing it.
Anyone else have experience installing these?
Old Jan 1, 2009 | 02:41 PM
BlkButy's Avatar
Go with the AS 2" - looks great rides the same - much cheaper!
Old Jan 1, 2009 | 03:18 PM
vtron's Avatar
Installing shocks isn't too hard. Just go to Autozone or Advance and borrow a spring compressor. They charge your card, then take off the charge when you return the tool.
Old Jan 1, 2009 | 05:59 PM
Djacobs28056's Avatar
check out this thread...
https://www.f150online.com/forums/20...eling-kit.html
Old Jan 1, 2009 | 06:15 PM
Definitly some nice truck's, well satisfied with my Daystar kit that's been in 3 1/2 yrs and over 40k miles with no problems.
Old Jan 1, 2009 | 06:42 PM
Spring compressors are very simple to use. I had to use one to take my GF 2" drop coils out of my stockers and put them in the Eibach dampers. That was the easy part of the install.
