How to adjust door tightness on a supercab
Old 12-22-2008, 11:18 PM
blackjack8900's Avatar
I noticed my passenger side door is not flush with the back door, maybe 1/16 to 3/16 of an inch.
The back supercab door appears to be tight but it's the front door that needs to shut tighter with the back.
How do you adjust the catch pins to make the door shut tighter?
I have not looked at it yet to see for myself on what it takes, if it was not -10 out I would be
Josh
Old 12-23-2008, 06:22 AM
momalle1's Avatar
The catch pins are not adjustable, all door adjustments are at the hinges. If you PM me, I can email you a pdf with instructions for adjusting the rear doors, the fronts are similar. When my front door wasn't closing tight enough, it was actually the rears that were loose, you could see the bottom of the rear door bounce a bit when you closed the front.
Old 12-23-2008, 12:59 PM
psk256's Avatar
momalle I have the same issue, PM sent.
Old 12-23-2008, 01:06 PM
pm sent.
Old 12-23-2008, 02:36 PM
artgarcia's Avatar
Same problem Here! I already sent my email by PM. Thanks!
Old 12-23-2008, 03:24 PM
momalle1's Avatar
If I missed anyone, please PM again.
Old 12-23-2008, 03:31 PM
mmcrorey's Avatar
any reason to not post it here so that anyone can download it?
Old 12-23-2008, 04:18 PM
alexarizpe's Avatar
Have the same problem with my passenger side. ever since they jacked my stuff threw the back passenger side window its never closed the same.
PM sent
Old 12-23-2008, 05:27 PM
momalle1's Avatar
Can I attach a pdf here?
Old 12-23-2008, 05:28 PM
05_sprcrw's Avatar
nope they will not let us use attachments which I still do not have a good reason why they won't let us.
Old 12-23-2008, 05:54 PM
momalle1's Avatar
Probably storage space, viruses, that sort of thing.
I'd copy and paste, but too much get's lost in the translation.
I didn't realize how many people would want these instructions, please remember to include your email address when you PM.
Old 12-24-2008, 02:34 PM
psk256's Avatar
Thanks momalle, got it.
Old 12-24-2008, 03:31 PM
Ryanmc86's Avatar
I have the same issue. PM sent. Thanks
Old 12-24-2008, 11:43 PM
gixxerjasen's Avatar
PM sent, I'll be happy to host it for you.
Old 12-25-2008, 02:42 PM
FastMag's Avatar
I have the same problem also PM sent. Thank you.
Quick Reply: How to adjust door tightness on a supercab
