Fogs and High beams
Old Jan 22, 2009 | 08:01 PM
  #31
john1102's Avatar
Ok....you're the best lol
Old Jan 22, 2009 | 08:02 PM
  #32
Screw-Me-05's Avatar
Originally Posted by ATOM
but on the 07 and 08's there is only 2 pins on the top. so if your holding relay in your hand,pin's facing down, the pin on the right side gets bent over.
Did the same to mine about 3 years ago and it still works like a charm. HID's and halogen
Old Jan 23, 2009 | 05:27 AM
  #33
Jimbo45's Avatar
but on the 07 and 08's there is only 2 pins on the top (the red line is pointing to the one that is missing on the 07/08) so if your holding relay in your hand,pin's facing down, the pin on the right side gets bent over.
My '06 only had two pins on top, too. FYI
Old Mar 28, 2009 | 04:55 PM
  #34
OneTomcat's Avatar
For those who have done this mod, does it reverse the foglight so they are on with high beam and off with low or are they on for both?
Old Mar 28, 2009 | 05:09 PM
  #35
ATOM's Avatar
they can be on whenever you want, with the high beams or lows.
Old Apr 23, 2009 | 08:46 PM
  #36
machsp33d's Avatar
not to hi-jack but i searched and didnt find a thread on this for the 97-03 trucks. is it the same for that style. I know my '04 mach 1 all i had to do was break a prong off my fuse...thanks guys!
Old Apr 23, 2009 | 09:26 PM
  #37
VTHokieF150's Avatar
Its different. On my '97 I had to jumper a couple wires together in the harness to the headlight switch. That was a long time ago though and I don't remember which it was, but search google because its definitely out there. I got it off the internet when I did it years ago. Also, to get the fog lights to come on with the parking lights, I had to file down a certain part in the switch that prevented the **** from being pulled out unless it was in the headlight position.
Old Apr 27, 2009 | 10:47 AM
  #38
machsp33d's Avatar
Ya, i got it now, thanks guys!
Old Apr 27, 2009 | 06:37 PM
  #39
boomer08's Avatar
Did it on my 04 when I had it and now I did it on my 07. Works like a charm
Old Apr 27, 2009 | 09:59 PM
  #40
LEDF150's Avatar
I just did it and it turned out great. I never realized how dark it was right in front of the truck when the high beams are on. Now I just need to get some decent pictures of my truck.
