Serious question: 1000HP
Well Id like to keep the whipple as it was 5 grand (hah). However, a STS turbo goes directly into the throttle body which I would have go directly into the whipple. Id probably run a ford gt fuel pump to huge injectors with a injector driver like you said.
Im now wondering what 8 PSI on a stroked 6.36L would make power wise.
Injectors in a diesel are VERY different then in a Gas motor. For huge gas injectors its probably 400-600 a set of 8.
No, the whipple will spool the large turbo up quicker, as the supercharger dies out in the higher RPM, the Turbo will really take over and give it that extra kick. In reality the supercharger only works part of the RPM band and the Turbo works the rest although they work together at the same time.
One hell of a pipe dream.
Do you also plan to daily drive a 1000 hp car?
I've been there in the mustang world and it is far from a daily drivable car. The big fuel pumps you'd need for that power make soo much dam noise and heat the fuel up really bad. There are just soo many little things that become a major PITA when reaching that 1K number. Your daily driver then turns into a weekend warrior.
I'd just build the block and throw 16 psi at it. I'd guess in the range of 600 rwhp on a safe tune and can drive anywhere, in any heat, on any gas.
Someone (I think it was hellion turbo systems) put a twin turbo system on a stock terminator cobra using a compound boost setup (turbos feeding the s/c) and made some insane boost # in the manifold and put down ~1100 at the wheels.
Reaching the 1K power level can easily be done with turbos or a compound setup but I have to agree with sbchris, it more than likely will be unusable as a DD. Not to mention you will have a hard time trying to get a tranny that will survive.
Ah well, I think Ill try that stroker kit and stick with the stock whipple. Atleast that way I have a built bottom end that can easily handle the power, and then the next thing would be tranny.
Make your PCM think you have a manual tranny and get an external auto transmission controller with a 4R100.
It is IMPOSSIBLE to attain 1000hp with a stock fuel system. A stock fuel system could not support anywhere NEAR that sort of power due to volume delivery, injector size, pump capacity.....there are a hundred reasons why this is not possible.
go to dirty dog on tccoa.com forums. he is one of the best there is. RAFA ended up going to him. he can build one that will take ANY power you can make.
this thread is the performance that is possible with this motor on stock heads with cams and good intake with forgings.
http://forums.corral.net/forums/showthread.php?t=556770
he ran 11.40's before he pulled the motor.
Could you be more specific when you say "stock fuel" ?
Yea I was going to dirty dog for a converter, Ill have to talk to him about a full blow trans!
Take a look at Josh's truck over on NHTOC. He just took the world's fastest Harley Davidson F-150 title away from Johnny Lightning Perofrmance:
http://www.nhtoc.com/vbforum/2000-20...1-126-mph.html
Look up Joes Twin Turbo Ford GT. Everything is stock but the twin turbos instead of a blower. He gets into 1000HP before needing to upgrade. Hence why I was thinking of taking the stock GT parts.
Statement recanted then.
I was not thinking "Ford GT" when you clearly typed "Ford GT". I was thinking Mustang GT....:o
The Ford GT already has some very serious race parts installed and can support that sort of power upgrade without too many mods.
Get ready to take out a loan though. 1000 RELIABLE HP is expensive regardless of which route you take to achieve it. My Mustang is making roughly 650FWHP (makes 540rwhp) on ultra conservative tunes with ONLY 7lbs of boost and keeping the redline at 6000RPM to keep the harmonics in check and avoiding the OEM block from splitting. If I can just get my hands on a Dart or Boss block and swap everything to it, I would be closer to 750+ FWHP, at least!
. Not cheap.
