got a few ??about lifting a ford f150 4x4
Old Nov 19, 2008 | 06:18 PM
85stangbanger's Avatar
I guys and girls new here with first post.. i am looking at buying a f150 4x4 with a 5.4 and wonder what is the max lift to go with without tearing things up.. I see alot of 6" lifts just wondering if this is a good idea or not.. anything i might need to know
Old Nov 19, 2008 | 06:27 PM
mxrider38's Avatar
I have a rize 8" lift with 37s and have had no issues. I have had it on the truck for about 2 years now. The quality of their kits is above and beyond any other 8" I have seen. If you are looking for a truck I can help you out with one of those too!
Old Nov 19, 2008 | 06:31 PM
i want to run maybe a 35" tire on some 18's or 20's with a 6"lift if possible but i want it to be reliable and not tore up all the time.. also am i going to have to do gears
Old Nov 19, 2008 | 06:35 PM
mxrider38's Avatar
Well I am running 20s myself. If you want a 6 rize also makes one or I my second choice would be a fabtech. Gears would definately be a good option. I have stock with my 37s and they would definately help. Depends on what you are using the truck for.
Old Nov 19, 2008 | 06:47 PM
Texan Aviator's Avatar
BDS makes a nice 6" lift. I have 10" with 38s and 4.56 gears are plenty for this setup if you drive highway as well as offroad. Unlike many on here I use my truck to drive to work AND hunt/offroad. I've had the lift on for 1.5yr and so far zero issues and zero regrets. But for a 6" I'd get the BDS, it's a quality setup.
Old Nov 20, 2008 | 05:47 PM
are you guys that have these lifted truck are you ya'll having any tranny issues or anyhting else that i may run into
Old Nov 20, 2008 | 09:45 PM
FX4life's Avatar
Rize actually no longer makes 6" kits. Rize is good stuff for 8" plus
anything 8"+ just requires a few extra things
-regear soon after or with the lift for 37's+
-Possibly-probably need driveshafts
-longer brake lines
Majority of people with 6" dont need the last two, and its a good idea to regear with anything 35+ it reduces wear and tear on the tranny. Ive had no driveline problems to speak of, and no problems with the lift. but i regeared, got new driveshafts and the kit comes with brake lines
Old Nov 20, 2008 | 11:58 PM
onjacks's Avatar
Sorry to hijack. FX4Life. A question?
Why do you say driveshafts
The only driveshaft that needs to be replaced (lengthend) Is the rear. Correct?
Old Nov 21, 2008 | 12:20 AM
FX4life's Avatar
You could just do the rear i guess, but why? they are both going to be short?
They lengthened both of mine. I dont guess you have to get the front done, but why not, it cost me less than 500 bucks for driveshafts. I figured going into it id spend 1k+ for the driveshafts, new joints, paint, labor and balancing.
You have to remember needing driveshafts is hit and miss, even rize will tell you that. I needed them so have a few others but i dont think Texan had to have any.
Old Nov 21, 2008 | 06:13 AM
so if i went 6" i should be fine with no issue's correct?? also you guys have some nice rides..also what would i regear to..this will be a daily driver
Old Nov 21, 2008 | 10:56 AM
FX4life's Avatar
You would be fine with a 6" lift, only issue might be you want more lift after its all said and done with a 6"lift and 35's you would want to regear to 4.56's. Most of us with 8" plus have zero problems after its all said and done
Old Nov 21, 2008 | 11:47 PM
are the 04 and up better then the 97-03's
Old Nov 22, 2008 | 12:30 AM
zeruin's Avatar
hmm.. well I'm going to say.. obviously, yes.
anywho.. I have a 2008 FX4 with the ProComp 6" lift, 35" Toyo MT on 20" wheels.. My truck drives great.. I did regear to 4.56 just for the peace of mind and more get up and go. Personally, for being a Supercrew, I think my truck looks and feels very proportioned in having a 6" lift and 35" tires as opposed to being stock, or going any bigger.
Old Nov 22, 2008 | 02:31 AM
Impact9's Avatar
I'm running the procomp 6" as well But added bilstein 5100's to push my front lift to 8" and put in a AAL kit in the rear to bring it up higher. I'm actually a bit high in the rear but not by much. My drive shaft angles on the front are actually pretty good compared to others.
Old Nov 22, 2008 | 08:49 PM
yeah thats doesn't look that bad at all..thanks guys for all the info and keep it coming
