Truck leaning?
Truck leaning?
This morning I noticed that the rear of the truck was leaning a little left (driver's side). I read some threads but I've always seen this happen on the older style trucks. Anyone notice this on the 04 - 08s?
I see there are some differing opinions from the threads but one that always comes up is a full fuel tank. Well I did fill-up yesterday. If anyone has some suggestions please let me know. Thanks!
BTW 05 SCREW FX4, 2"AS, 285/60/18 BFG ATs
There are 3 possible reasons why you've got "the lean":
I'm going to assume the shocks are going bad. Do you notice saggy or bouncy behavior?
- The right side shock is going bad (causes the right side to be higher)
- The left side spring is bad (causes the left side to sag)
- The right side shackle is hung up (causes the right side to be higher)
I saw a dump truck like that the other day... I said, "Damn!!! That must one fat driver!" haha
But on the lighter side... it means the shocks are dead. To keep driving it like that results in bad gas mileage, bad tire wear, and wear on other parts too that will likely cost more than replacing that shock a while back.
But I've never noticed before this morning. And I've needed V8 Juice for a while.
