Too busy fixing it to mod it
Old Aug 19, 2008 | 08:03 PM
Penguin86's Avatar
my truck is really starting to bum me out, seems everytime i drive it I found something else wrong.
things to fix...
new brake pads (bought those today..brother will prolly put them on tomorrow)
new rotors
fog lights leaking water
loud squek comming from rear when going over the smallest bump
rattling sound comming from the front
fuel door broke ($83 for part and labor)
so my leveling kit sits on the counter...i've had it for months now..just never get the money or time to put it on.
plus all the other things i'd like to get done to it..but ah well it shall remain stock for now
Old Aug 19, 2008 | 09:52 PM
4.6 Punisher's Avatar
The squeak is just the frame/suspension flexing. The rattling is probably a different story though.
Old Aug 19, 2008 | 09:58 PM
Penguin86's Avatar
you really think so?
the squeking annoys the he** out of me, it never did it before but now it's been doing it cause i'm back in my home town and the roads here are horrible
Old Aug 19, 2008 | 10:51 PM
My Ranger used to squeak and beg for mercy every time I went over a speed bump. It also had a broken leaf spring so it probably did deserve babying. Now Carmax has to deal with it!
Old Aug 20, 2008 | 01:50 AM
azmidget91's Avatar
clean the under side of your truck really well and spray some wd 40 on the leafs
Old Aug 20, 2008 | 08:16 AM
05FX4SCREW's Avatar
I had the same thing when I got my truck. I sprayed the crap out of the leafs which took care of some of it. The rest of the noise was the tailgate latches which got quiet once they got sprayed down with some more WD-40.
Drilling a small hole in the bottom of the fog light housing will provide a band-aid for a while. Water will leak out and air will get in to take care of the condensation. just try to find an inconspicuous spot to drill and it only has to be a small hole. This worked on a few of my cars.
Old Aug 20, 2008 | 11:55 AM
projetmech's Avatar
you got silverstars in the foglamps? i did and noticed a leak or should i say water in there. i blew some compressed air in there at about 5 psi for 10 minutes to dry it out. put a little silicone on the lamp base before putting back in and it was good. since then both fogs have burnt out and i put the stocks back in cause i talked to a couple other guys and they had the same problem with them burning out. i cleaned all the silicone off prior to putting the stock bulbs back in and they did not leak.
Old Aug 20, 2008 | 12:00 PM
Penguin86's Avatar
nope the fogs are stock.
and as soon as I figure out what/where the leaf is i'll spray some wd40 lol
sorry i'm about as dumb as it gets when it comes to vehicles but i'm trying to learn!
Old Aug 20, 2008 | 12:36 PM
scott1981's Avatar
x2.
Old Aug 20, 2008 | 12:38 PM
Crstfr's Avatar
i had to replace one fog already.. 100+.. it leaked.. .now my other is shot..leaking as well.~... .grrr..
i hate not having my foglights~
chris
Old Aug 20, 2008 | 12:39 PM
05FX4SCREW's Avatar
leafs = rear springs (big, flat, horizontalish metal pieces that go front to rear at your back axle)
JMBdevotee's Avatar
Originally Posted by 05FX4SCREW
... The rest of the noise was the tailgate latches which got quiet once they got sprayed down with some more WD-40....
I had a REALLY annoying squeak over every little bump. If I opened up the rear window I could hear it over the radio. One day I was going around the truck and pulled on the passenger side of the tailgate and it made "the" sound. Hit it with some WD-40 and it has been good-to-go.
Old Aug 20, 2008 | 01:15 PM
phatboyspam's Avatar
ummm if he doesn't know what a leaf is i wouldn't guess he knows what an axle is? (no offense)
but the leafs look like a prehistoric BOWFLEX(yaknow the work out machine)..
Old Aug 20, 2008 | 01:26 PM
Penguin86's Avatar
actually thats what i figured the leaf was, i just wanted to make sure before i go spraying stuff lol
and i'm a girl
Old Aug 20, 2008 | 03:25 PM
Instead of buying our cheap thin fog lamps all over again, remove the lense from the housing and re-silicone them on good, no more leaks. Squeaking from the rear may be a bad exhaust hanger, the leafs, a brake shield, brakes never last forever. I see its 2004, any idea what thew history was with it? or did you buy it new? How many miles?
