Those running 37's
37X13.5 Toyo
Awesome guys, everyone's got such a nice lifted truck.. Im plannin a lift after this winter and this makes it hard to wait!! What is the pros and cons of goin w a wider tire. For some reason i like the 15.5 look...
In my opinion, it balances the look. Especialy if you are running 10" plus of lift. My 37's look pencil width on my truck from the front.
dude i cant believe you dont rub! or do you ?! lol
i also have 36x15.50
Depending on the angle my 13.50's can sometimes look to narrow, that might be due to my rims being only 8.5" wide though.
I saw an H2 the other day with 38x15.50's on it and I thought it looked goofy. Not a fan of tires that wide unless you go really tall so the tire doesn't start lookin square.
An 8" lift like the rize gets you the height while keepin your cv's close to the stock angle. A 6" kit with a 2" spacer or coilovers cranked gets you there but adds some angle to your cv's.
I got the rize 8" just to keep the cv's close to stock being overly cautious. I'm not a fan of the rize crossmember though, I like the looks of the procomp kit with an additional 2" alot more from the front, just looks cleaner. I'd think a 6" plus coilovers would be close to the price of the 8" rize.
look if you want it done right you need to spend the extra money. CST and Rize are the only two companies that make 8" lifts... oh and BDS but im not a fan of there stuff. spend the money on an 8" you'll be happier in the long run.
haha...I like the simple bar crossmember instead of the fabtech and rize ones that draw more attention. I've always thought the suspension/underside of a ride should be low key and not draw attention away from the truck. I'm wierd with alot of things though
I want it done right as well.. Who makes a bracket for my airbags? I still tow heavy boat and don't like sag..
i thought of ya neuspeed5 but i couldn't remember your name
I just didn't (and still don't) believe it will have held up off-road. Sure may be ok for on-road use but... Angles were bad, IMO.
And PS: for the love of god do stack spacers (ie autospring on top of pro comp.)
