bilstein 5100's
Old Jul 10, 2008 | 02:00 PM
05supercrew's Avatar
Originally Posted by dkstone05
Oh yea I forgot to mention that I had the AS 2" on it before and now with the 5100's at the 2" setting the front does sit a little lower than it did with the AS. Which I don't mind, it probably helped the upper ball joint angle some. The tires rub just the tiniest bit when in reverse at full lock. I don't have any before and after measurements but it is noticeable that it does sit lower than it did.
Really, I see you have the same rims as I do and im looking foward to swapping out my AS 2''. Did you get a wheel alignment also?
Old Jul 10, 2008 | 03:07 PM
dkstone05's Avatar
Yep I had them align it when done.
Yea we have the same wheels and same size tires(I have Toyo AT's though). I looked at your truck many times before buying wheels and tires. Don't think you ever mentioned your tires rubbing but mine did just a little when they were brand new (with the 2" AS) but they have worn down some now and stopped rubbing....well at least until the 5100's but like I said it is very very minor rubbing and will probably quit in a few thousand miles. I would do some triming some but honestly it is so minor that I cannot see where it is rubbing at. I would have to have some watch while turning in reverse to see it.
Old Jul 10, 2008 | 04:42 PM
Yah I never had rubbing issues at all and thats why I bought those wheels. I do some off roading and some beach runs so I need to change the shocks bad. Thanks for the input.
Old Jul 11, 2008 | 11:21 AM
Thanks for your input, I just pulled the trigger and ordered them from Topguncutomz. I should see them by next Thursday or friday.
Old Jul 11, 2008 | 01:32 PM
dkstone05's Avatar
Just incase you havn't read anywhere else on hear the topgun ones only have a 0" and 2" lift setting. I think it has to do with them being made for "RCI?" lifts but should have the same valving as the other with the 1" setting.....at least that's what others have said on here.
I don't think this matters much since you'll have to go with the 2" setting but thought I would let you know since I didn't mention it earlier.
Old Jul 11, 2008 | 01:51 PM
Thanks I didnt know that, but I definitly need the 2'' setting.
Old Jul 11, 2008 | 09:26 PM
mlawdawg's Avatar
Originally Posted by artgarcia
In usa with the quality of the streets and highway there is no problem at all.
Never been through MI,huh?
Old Jul 11, 2008 | 11:23 PM
wolverine08's Avatar
Yeah, some of our "paved" roads are worse than the back country roads that only see the grader 1x per year, part of the reason I am looking into the Bilsteins in the first place. Maybe they will be too harsh though? I have noticed a big difference in spring rate from my old '06 scab 4wd to this new '08 reg cab 2wd though, much softer ride but also telegraphs every bump thru the manual trans., that's why I'm thinking the Bilsteins may improve the ride and as a bonus can level up the front end.
Old Sep 9, 2008 | 12:20 AM
DATS TTRAH!'s Avatar
my father has the new tundra with the TRD package and they come with the bilstein and i really like his truck off road. the big bumps are small and the small bumps feel like cracks. their sweet, im about to order the knew hotchkis hps1000 for my harley BUT WONT BE ABLE TO TOUCH THE OFFROAD!
Old Sep 9, 2008 | 04:07 PM
I bought a Bilstein 5100 level kit for $380 from Top Gun Customz and am waiting for my friend to help me put the rear shocks in and have a shop install the front. Looking real forward to the new height in front. I love these north PA smooth streets
Originally Posted by wolverine08
the rake on my '08 is not at all like on my '06 scab 4wd, seems almost level, but needs about 1" in the front.
It will sag down more soon as soon as those front struts break in. Since they are brand new they sit a little higher.
