TPMS Remote Fob Question
Old May 27, 2008 | 01:06 PM
Smokewagun's Avatar
My 2008 F-150 Supercrew Ownre's Manual says my truck was delivered with a small "key fob-like" remote to reprogram the computer when the tires are rotated. It even tells you where to put it in the Owner's Manual zippered pouch so you don't lose it. Mine never came with one. My dealer says none of them come with it, but they would order one. I rotate tires often, so I am sure I'll use it. Has anyone received one with their 2008 truck?
I know rotation has not been an issue for some, but I am running 80psi (possible) LT tires, which I should run close to 55 for daily driving. This is a far cry from the 44psi door sticker. At 44psi in my tires, I'd be running "Low", but the sensors will see 44psi and think I'm running fine.
Old May 27, 2008 | 03:16 PM
CWCobra's Avatar
I did not receive one with my 2008 Limited...did not realize I had TPMS. I have 10,000 miles now, so I am past-due for a rotation.
Thanks for the heads up.
CW
Old May 27, 2008 | 03:24 PM
Blue150's Avatar
I didn't get one either, not that I know of. Do you know what it looks like?
Old May 27, 2008 | 04:09 PM
JesseRohr's Avatar
When I rotate on my 07, The TPMS comes on for about .25 mile or so then it goes off. It just recalculates I am guessing. My owners manual says the same thing about a small key fob. What gives.
Old May 27, 2008 | 04:13 PM
Blue150's Avatar
This might explain it. http://www.aa1car.com/library/tire_monitors.htm
Old May 27, 2008 | 04:33 PM
Shane1's Avatar
I rotate about every 5k with out seeing the TPMS light. It's wierd that some see it after rotation and some don't.
As far as your situation 44psi might be low but it's probably not the danger zone for your tires. If it is then I would just take it to your dealer and have them reprogram the sensors to a higher PSI. It should be free since the manual states we should have that capability anyways.
Old May 27, 2008 | 05:37 PM
italiano's Avatar
that dealer lied.i recently worked at a dealer and i had to do pre delivery inspections on the new vehicles that come off of the trucks.all the 2008 trucks and vans had this remote.i believe some of the cars had them as well.i have seen them in almost every truck so they need to fork it up.thats 2008s though.
Old May 27, 2008 | 05:52 PM
BlueOvalFitter's Avatar
Exclamation
I've had my tires rotated 3 times at the dealer and rotated and balanced at a local tire store once and never saw a TPMS light come on!
Old May 27, 2008 | 06:10 PM
So dumb...
Why does Ford plague it's customers with such stupidity?
Old May 28, 2008 | 12:17 AM
italiano's Avatar
the best thing to do is get the tires rotated and drive it after for about a half mile over 35 miles an hour and if it doesnt go out then go complain.i have no idea how the hell those things are supposed to work anyway.i have done tire rotations with no issues that i know of.i wouldnt even worry about it.
Old May 28, 2008 | 12:49 PM
pldjr0187's Avatar
TPMS Fob
I did not receive one either. I took delivery on Tuesday. I called my salesman Tuesday night and he said "He would get one right away and send it to the house."
Old May 28, 2008 | 01:00 PM
Blue150's Avatar
I will be surprised if you get anything different than your key fob. If you do, post a picture. Please.
Old May 28, 2008 | 01:57 PM
kingfish51's Avatar
You should not need one. That is only for vehicles that have a recommended tire pressure that is different between front and rear (see F250s up). F150s come with a recommended pressure that is the same all around.
Old May 28, 2008 | 02:06 PM
Wrong.
The Heavy Duty F150's have 50 PSI up front and 60 PSI in the rear.
Old May 28, 2008 | 04:33 PM
kingfish51's Avatar
Wrong.
That may be, but again it is only for vehicles that have different pressure recommendations between front and rear.
