Gatorback serpentine belt install help
Old May 25, 2008 | 10:25 AM
gators241987's Avatar
Ive got the belt, i see the directions, but how the hell do I fit my hands all the way down there and through all of the crap?
Old May 25, 2008 | 10:31 AM
ELVATO's Avatar
Before I had my e-fan, I had to as much as I could on top, then get on the floor, reach up, and finish routing. The e-fan makes it much easier.
Old May 25, 2008 | 10:35 AM
davenay's Avatar
A 1/2" socket driver plugs straight into the tensioner, and allows you to loosen the belt. After that, you just start un threading everything. When you loosen tension, the easiest pulley to undo is the alternator, then you can let go of the tensioner.
It's all a tight fir, but you can do it without removing the fan and shroud.
Old May 25, 2008 | 08:58 PM
shoot, anyone from the memphis area wanna give me a hand? i think we can work out something for your time
Old May 26, 2008 | 01:49 PM
shaunakadub's Avatar
It's defiantly easier to work from both the top and bottom.
I'd suggest sitting there before you start for a few minutes and just making a metal note of everything you see having to do with the fan. Keep that metal image and have a buddy loosen (easy to do by yourself too) the tensioner with a 1/2 breaker bar. Then just un-route it, and re-route it.
After you finish the first time you'll realize how easy it really is. Takes about the same time and labor as an oil change.
Old May 26, 2008 | 02:11 PM
Yes, it is always easier when you have a plan of attack before you do any work you're not accustomed to doing.
Old May 27, 2008 | 01:54 AM
extremeethan's Avatar
WTF? I have big hands and did the belt change in like 2 min? I dont remember having any problems
Old May 27, 2008 | 02:02 AM
Racing2Fast's Avatar
I installed one on my truck, it's a tight fit, but can be done.
Im off work this week, so PM me and I'll give you a hand with it. No big deal!
Tom
Old May 27, 2008 | 02:21 AM
If you think changing the serpentine belt on your longitudinal engine is hard... try a latitudinally placed engine... that is a NIGHTMARE!
I can change a serpentine belt with NO tools if it's got an auto pretensioner... just takes a little bit of muscle... and faster than you can go and get that socket and breaker bar.
Oh, and just be careful of your fingers if you do it... as it hurts if you get your fingers stuck on a tense belt.
Old May 27, 2008 | 01:10 PM
ManualF150
Your AWESOME!!!
Tom
Old May 27, 2008 | 01:39 PM
when you put it back together, put the tensioner about half way and hold it there (just starting to put tension on the belt), and spin a pully/belt and make sure the belt is seated correctly on all the accessory pullies
also might help to take off the intake tube on 04+ trucks
Old May 25, 2010 | 01:35 PM
TNoff's Avatar
I'm just glad this belt has nothing to do with the timing nor does it require more than one tensioner nor does it require a special tool or moving the engine up and down off the mounts. My DSM was one of the hardest to do. This sounds fairly easy.
Old May 25, 2010 | 01:45 PM
Labnerd's Avatar
I had to print this thread and send it to one of my old techs, LOLs. He would cut the original belt off, lace the new one on, have somebody start the engine and slip the belt on the power steering pulley with a screw driver. He's the only person I know good/dumb enough to make it work and not get a broken arm out of it. I don't recommend you try it!
Old May 25, 2010 | 01:59 PM
TNoff's Avatar
I almost want to try this.
Old May 25, 2010 | 08:09 PM
subcooled's Avatar
If you try it, you have to give us a video
