Keyless entry & Alarms
Old Apr 30, 2008 | 10:49 PM
Bulldogbud's Avatar
Ok so i have a power nothing stx. and well im sad to say 4 cars have been broken into at work. i want to get keyless entry and alarm anyone know any good ones and also ones that wouldnt be hard for me and a buddy and a cooler full of beers could handle? i have been thinking about goin to mobile one and getting one but it would be around $500. any imputs?
Yes i know it wont stop them but we can hear a car alarm go off at work to let us know whats up....of course all the cars that have been hit have no alarms.....and i dont want to be next!
Old Apr 30, 2008 | 11:06 PM
Budha05STX's Avatar
Send Monkey-1 a PM on here, he can hook you up and there's a few of us on here that can attest to the ease of installation and instructions he provides.
I too have/had a power nothing STX and he included everything I needed to get me going.
Old Apr 30, 2008 | 11:13 PM
Bulldogbud's Avatar
one quick question. what route did u go for the keyless did u add any unlock/lock buttons, or do u just push the remote when u pick someone up?
Old Apr 30, 2008 | 11:16 PM
Monkey-1's Avatar
Thanks Budha!
Bulldogbud, I just emailed you. As for the switch, you can add an external switch if you like, but you can always use the remote to lock and unlock the doors.
Old Apr 30, 2008 | 11:25 PM
Bulldogbud's Avatar
ok looking into it now...Much Appreciated!!
Old Apr 30, 2008 | 11:26 PM
Budha05STX's Avatar
No, I didn't (want to) add extra lock/unlock buttons....I just use the remote. I also went with LT door handles to eliminate the key holes in the doors and used the driver's rear door handle from a supercrew so I didn't have to mess with the keypad either.
NP stud monkey.
Old Apr 30, 2008 | 11:32 PM
Bulldogbud's Avatar
yeah isnt our keylocks easy to pop anyway? i ought to look into that too cuz then they could just pop my keylock too instead of breaking the window
Old Apr 30, 2008 | 11:38 PM
Bulldogbud's Avatar
hey studmonkey. u have any specs on the alarm? haha i called my buddy and he was like i dunno taping to the ignition is pretty tricky i dont want to mess anything up so i might have to take it somewhere to get it installed
Old Apr 30, 2008 | 11:47 PM
Budha05STX's Avatar
It's all color coded wiring and color coded T-Taps with color pics in the instructions to help you out. He supplies T-Taps and prewires the male spades to make it even easier.
Old May 1, 2008 | 12:07 AM
Monkey-1's Avatar
I will get you the full spec on them tomorrow, I am about to call it a day. It is really not as intimidating as you may think.
Old May 1, 2008 | 10:06 AM
Monkey-1's Avatar
Bulldogbud,
You have mail!
Old May 1, 2008 | 12:00 PM
TPC11's Avatar
Monkey
I have an 06 STX with the white terminal block. How do you suggest getting around the block with the wiring? I've seen the posts where the guys have drilled it out but the more I look at it, I think a new boot lower in the door would be better.
Thanks.
TC
Old May 1, 2008 | 12:19 PM
Monkey-1's Avatar
Originally Posted by TPC11
Monkey
Thanks.
TC
Those arent fun either way you decide to go. If you can get in the door jamb to drill a couple of more holes (one in the door and one in the jamb itself) thats another option you can try. You can get the small rubber boots to cover the wires to make it look factory. Really after you get the block apart, you can dremel or drill out the open area fairly easily. If you need the boots, let me know.
Old May 1, 2008 | 12:28 PM
TPC11's Avatar
I've looked at the block and you can easily see the open slots. I just really don't want to smuck up the block and have to go salvage yard diving for one.
I have access to a right angle drill so that's why I was thinking about just doing another boot and then I could run my door lock and possible power window wires through that.
Which way would you go?
I may be interested in what you have to offer. I don't need an alarm, just the power door locks, no switches either.
Shoot me an email tcoldren at hotmail.com
Old May 1, 2008 | 02:37 PM
Monkey-1's Avatar
You have mail....
I understand your hesitance, but other than it being a bit snug its not too difficult. If you feel more comfortable drilling an extra set of holes, the boots are pretty cheap. Just make sure before drilling you know what is behind where your hole will be.
As a side note, anytime I have to run wires through a boot I always run an extra 'pull wire" so that the next time I have to go in that door its easy to add more wires. It never fails people start out wanting JUST power windows and then in no time, they decide they would like power door locks. A little scrap piece of wire will make the second (or third) trip through the boot ALOT easier and quicker.
