What kind of side steps?
Okay so I have been going back and forth with this and I decided that I need steps. Plus my parents are giving them to me for graduation! The plastic piece in the door jam is getting cracked from stepping on it . I want some that stick out enough so my door doesn't get dinged and don't cost an arm and a leg. I don't know if I should get black or not... Can anyone sway me or point me in the right direction?
This is the most recent picture of my truck.
i used Dupli Color’s High Heat with Ceramic in flat black(got from napa)
i already had some that i painted my exhaust pipes with
i used about a can on each bar
i sanded them down w/ some 600 grit
even did the plastic ends and step pads then wiped them down w/ a shop towel and some carbmedic ...then sprayed several coats ...
exhaust pipe pic
I thought about nfabs but they are pretty expensive. I really like the amp steps but those are WAY to expensive. Would supercrew running boards fit on my truck? I'm trying not to find a cheap way out for my parents sake. Can anyone throw some prices are links?
